B20 vtec w/ a bottle ?
Old May 26, 2010 | 09:21 AM
DC2_BoostKING's Avatar
CRAWFORD BUILT
^+1
you running dry, wet, or direct port?
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old May 26, 2010 | 09:28 PM
CTR_Powered's Avatar
this is phatcivicboii, im running 75shots dry. thanks guys for the advises. will take inconsidration.
I LOVE PAPAYA SALAD AND STICKY RICE
Old May 27, 2010 | 09:16 AM
sxysweed's Avatar
CRX.XXX
Originally Posted by SupraMan91.5
The B20's Low Compression Is The Reason It Can Hold Up However I Wouldnt Reccomend U Revving The Hell Outta The Motor Because Then You Will Run Into Problems With These Weak Sleeves But Otherwise I Dnt See A Problem With A Wet 100 Shot
The low compression IS NOT why it can hold up.
Honda makes their engines to last, so they slightly overengineer engines.
Low Compression DOES NOT mean you can boost the hell out of an engine.
It just leaves more room for error and you can run a bit more boost.
That's all.
The sleeves ARE NOT why you can't rev the motor high.
It's the rods/bolts and the engine geometry. The engine stops making power at one point, and it does not need to spin (much) beyond that. They didn't build a 2.0L B16, so to cut costs, they found no reason to make it spin any higher.
The sleeves aren't necessarily weak. They are a different design from other Honda sleeves, and slightly thinner, but with good tuning you should be fine for a good amount of power. Almost every other honda motor neads work after a certain amount of power anyways.
IMO, you either run a dry shot of nitrous, or you go Direct Port. Wet or Dry, it's your choice on DP. But a wet 100 shot doesn't sound like a great idea.
Old May 27, 2010 | 09:23 AM
custom240sx's Avatar
DC Crew Member #1
Wet nitrous shots are horrible. Get it tuned with a dry setup and bigger injectors and dual map sensors. Let the computer adjust fuel levels don't try and guess with a pill size.
The sleeves are the same as a b18b1/a1 sleeve design. It is basically just a bored out b18 block so yes the sleeves are weaker but they can still handle 300whp fine. TUNE DEPENDANT!!! can't stress that enough.
Old May 27, 2010 | 08:12 PM
Secondz's Avatar
Built Not Bought
Originally Posted by custom240sx
B20's are fine under boost...your b20vtec should have made more power than 300whp at 10.5lbs...what size turbo are you running?
A small t3/t4 hybrid
Old May 27, 2010 | 10:17 PM
DC Crew Member #1
And I'm guessing a log manifold correct? Still fun none the less.
