wheel bearing?
Old Apr 10, 2010 | 08:00 PM
DC2_BoostKING's Avatar
CRAWFORD BUILT
Default wheel bearing?
correct me if i'm wrong but when a wheel bearing goes it makes the grinding sound all the time right? mine only does it from a cold start, then after 15-20mins of driving it goes away and doesn't come back until it sits for a while.
and i know it's suspension related because the sound changes as my speed changes.
CRAWFORD BUILT
Gainesville Crew Member #1
DC Crew Member #23
Old Apr 11, 2010 | 04:09 AM
rangcrx's Avatar
engine building &best
no it does not always make a sound but over time like the cvjoint the grease wears then the ballbearings become warn and give it play,so if you take off your brakes and your rotor has play then time to change the bearing.it should have no movment what so ever
i love AUTOZONE
Old Apr 11, 2010 | 05:37 PM
SUPAFLY's Avatar
tru but u dnt even have to take the brakes off to check it jack up your car and shake the wheel up and down if it move bad wheel bearing
TR "Old Skool EF" Member #152NO BOOST!!!!JUST MY FOOT AND THE BOTTLE!!!!!CRX SiR
88 crx dx-wrecked
91 crx si -project 300 whp allmotor-solddd
95 teggy-parting out
91 ex 4 door -sold
97 ek civic dx boosted-400whp
98 teggy gsr-dd
8137704076 b series parts for sale let me kno what you need
Old Apr 11, 2010 | 07:21 PM
CRAWFORD BUILT
gotcha, yeah i checked it today and there was no play in it. plus the sound went away and hasn't come back. i'm not sure what it was so i'll be looking the suspension over this week when i get a chance.
CRAWFORD BUILT
DC Crew Member #23
Old Apr 11, 2010 | 07:28 PM
89crxsir's Avatar
if you would turn side to side driving down the road, the sound should chage if it is a bad bearing
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
Old Apr 11, 2010 | 07:32 PM
CRAWFORD BUILT
sound stayed constant with speed, regardless of direction.
CRAWFORD BUILT
DC Crew Member #23
Old Apr 14, 2010 | 12:15 AM
Sometimes a bearing without enough grease will heat up what's available
and it will quiet down when it flows back in....not good for the bearing to run dry at first....or at all. When cold, can you feel any roughness as you press against the wheel and turn it?
How do you know it has an abundant supply of grease?
Any looseness at all?-Bob
Old Apr 14, 2010 | 11:08 AM
CRAWFORD BUILT
no play what-so-ever in it, and the sound still hasn't come back. i don't have power steering so i'd be able to feel it, but nothing.
CRAWFORD BUILT
DC Crew Member #23
