fucking hondas!!!!(keystuck)(wont start)
Old May 17, 2010 | 05:03 AM
K20dream's Avatar
Cool fucking hondas!!!!(keystuck)(wont start)
well i just bought this 4 door stock so idk my car wont turn over it wont do anything when i turn the key makes no noise its not the batttery maybe the starter or ignotion switch the other problem is that the key gets stuck it wont come out the ingnotion unless i disconnect the battery so to start it i have to push it to start , i need to fix it asap plzz help me outt
Old May 17, 2010 | 09:35 AM
K20dream's Avatar
upp
Old May 17, 2010 | 10:32 AM
jingram20's Avatar
In the work's
Id check the ignition first if i were you it sounds like the ignition to me...
Old May 17, 2010 | 10:54 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Is the car automatic?
-Winston Churchill
Old May 17, 2010 | 11:05 AM
Lime_Green_Hatch's Avatar
what year is the 4 door. try to manually give power to the starter see if makes any noise or tries to turn over... if i remember right (its been awhile since i looked at one) but there should be a remote wire on the starter its a small wire i think it was green in my honda. if i remember right if you add power to that wire it should turn over.. if it doesn't the starter is bad if it does turn over its the shit up by the key the connectors on the ignition wear out.. it happened to me.. the key worked everything else but the starter.. all i did was add a push button starter button and hook it up the starter it worked great all you had to do was put the key in and turn it and then push the start button i hooked up... and you can hide the button so thieves would know were to look for it... they would just think it has some ignition cut off switch
2011 BMW S1000RR
2008 NINJA ZX-10 - sold
2009 NINJA EX250 - sold
2006 NINJA ZX-14 (wrecked)
2005 NINJA 636 plasma blue - sold
Seductive Cycles
Old May 17, 2010 | 03:02 PM
InTeGrAcInG's Avatar
stay thirsty my friends
check the clutch also. just bypassed mine clutch switch cause of the same symtems.
Old May 18, 2010 | 04:32 AM
96awdturbo's Avatar
I don't know about the key getting stuck but like mentioned ^ check the clutch safety switch it's the first switch above the clutch. Also the Map or Maf which ever it is you have.
Old May 18, 2010 | 04:40 AM
K20dream's Avatar
its a 97 4 door and its 5 speed and i did put a power wire to the starter it just mad noise didnt start it and idk now my temp guage is not working so im no sure if its overheating or not but the only way to start my car is to push start and the only way to take the key is to disconnect the battery
Old May 18, 2010 | 08:31 AM
sxysweed's Avatar
CRX.XXX
Check the starter,
have the battery tested,
main relay/clutch switch?
Does it run once it's push started?
Old May 18, 2010 | 11:16 AM
K20dream's Avatar
yeah battery is good and yeah it runs once pushed im going to cheack the clutch switch in a few and does autozone check starters too?
