Heater Core Hoses! Help
Old May 3, 2010 | 05:42 PM
Honda Kid07's Avatar
Default Heater Core Hoses! Help
Whats up TR
so i took the whole heater core system out. and i was left with the hose that comes off the block to the heater core hook up inside the motor bay area.
what do i connect the hose to that is comeing off the block?
here are some pics:
here is the hose that is on the block. right under my Vtec Solenoid.
This is the pic of the heater connector thing.
Old May 4, 2010 | 02:26 AM
rangcrx's Avatar
engine building &best
just go to ace hardwear and buy a U pipe to loop the hoses together its like 1.20$
i love AUTOZONE
Old May 4, 2010 | 07:02 AM
Hey,
well there is a hose coming off the back of the block that goes into a pipe. ill get some pics up today.
Old May 4, 2010 | 09:18 AM
Here are some extra pics
this is the hose on the back of the block that was going to the tube for the Heater core
these are pics of the tube coming from the back of the block under the throttle body.
Old May 4, 2010 | 02:21 PM
any suggestions?
thanks
Old May 5, 2010 | 11:41 AM
BUMP.
still looking for help.
thanks
Old May 8, 2010 | 09:01 AM
BUMP
can i just put the hose that is under the Vtec Solenoid on the tube under the Throttle Body?
to this tube
Old May 8, 2010 | 07:35 PM
Get the rubber cap-off plugs for your size of heater hoses.
Maybe from Pep Boys/A-zone, etc.
As a general rule:
Put a cap-off plug anywhere a hose would have connected.
That U-pipe is a good idea, also. If it is the right size.
Pics are better than nothing, but sometimes it helps to see it real.
What part of town are you in?-Bob
Originally Posted by Honda Kid07
Hey,
Old May 8, 2010 | 07:46 PM
IM in Ocala
Old May 8, 2010 | 09:14 PM
Rats. Pretty far to go....I'm in Tampa...
I ask because I just converted my (different from yours) car over to a cold non-heated intake....heater works, gauges work...but for me to describe what I did is almost impossible.
As a general principle, all metal pipes need to be either capped off
or a hose connected to them....and with some luck there will be an even number and/or pipe sizes will be the same.
If all you did was remove the heater core, connecting heater hoses to Rang's u-pipe may be your best bet.-Bob
IM in Ocala
