- anyone have wheels i can borrow on sunday?
- Slick/wheel Combo?
- Paging Shawn Miller ! Lakeland
- accord
- Single cam ZC head on d15 block?
- Lovefab SST
- is there head work to be done???
- installed vafc...car now runs like $&*#
- Help With Parts On My Head
- The Deal Pm6 91 si Turbo Edit
- Best Piston Choice for All Motor Ls?
- 1997 Honda Accord needs repair.
- OBD0 PR4 Ecu pinout
- Skunk2 Intake Mani... leaking gas
- Where to buy swaps locally?
- B series specs
- just an FYI for those in here...
- Turbo Experts::::T-3 or T-d05-3 on my LS?
- Dumb Teg Exhaust Question?
- gas tank size
- idle
- injectors
- Bleeding the clutch fluid (94 Honda Accord)
- Teg Troubles
- H22 type S cams
- f22 swap for civic hb?
- 2000 gsr dizzy on b16a head????
- Rubbing noise from rear
- Tunning Help
- NEED Help FAST for b16a swap!!
- what kinda motor
- want to rebuild the b series
- b16a turbo on a d16y8?
- cheap easy way to boost hp
- pwo and pr3
- Need help
- intake that connects to headlight
- flywheel and clutch question
- Need some opinions on my compression...
- Hondata Question
- 1g or 2g
- Damn Honda :-(
- lost motion?????
- Aidos 4th....
- TECH: Engine break-in's
- NEED HELP removing upper ball joint on RSX
- Machine shop recomendations
- Vacuum diagrams for a 95 GSR
- f22 conversion ques
- engine help
- Timing belt change, H22 EK - FYI
- Burning oil?
- WTF: Is there a difference in the 98 and 99 civics?
- Dynoed the Ark today
- question about walbro fuel pump for tegs
- suspension shop
- Gauge Cluster Problem
- integra Shifter o-rings????
- pr30s or p73s which be better??? help
- Tail Light Problem
- STOLEN 93style white hatch with b18c
- need help with tunning on my b16a2
- Finally!!! Some better Numbers!!!!!!
- turbo questions
- vtec quetion
- Nology Hotwires
- Check engine light? Help!
- aint this the shit
- Broke 200whp today :-)
- 90 hatch doing ls swap
- To Sleeve Or Not To Sleeve, That Is The Question
- am i wasting gas or harming anything not useing O2 sensor
- HELP Me!! question about b16a1 wiring harness!!
- type r in eg.....brakes
- resistor box/ injector install
- Anyone know how to install an shift-light properly?help me out.
- Re: Help with air fuel
- Looking for Accord 4lug steelies
- Mini Me Help
- civic type r pistons
- Guage Cluster HELP!!!
- H22a Tcu
- speedometer not working?
- <<<< TR Shirt Pictures And Information ! >>>>
- crx parts needed
- What happened to testpipe.com???
- testpipe question
- vtec problems
- i have a camshaft question??
- 2004 Florida CRX/ Civic HB Meet!
- LS/Vtec to the max
- WTF mate???
- ecu programming
- Spun Rod Bearing!!! Help!!!
- hellp me plz im fu***d
- !!PICS!! Of My EK Hatchie!!!
- Full Race LS Intake Manifold Interest
- Upgrading Help
- TECH: Engine internals info.
- codes and msd
- who has ESPELIR EXHUAST how is how does it soun
- Help on CRX BUILD UP
- auto to manual??
- master cylinder
- bodykit help
- $$$$seals$$$$
- possible?...need help
- Next H/a Meet - October 10th!!
- good or bad? dyno sheet
- schematic on adding res/diodes uberdata
- Need kinda quick response.
- ecu upgrade
- corners for teg
- finaly on, is it ok?
- Name Me a Good Brand
- Integra Radio code?..
- what do you think about this car?
- electrical problem?
- Maybe it is spelled 'vtech'???? *pic
- bogging out at the begining of each gear?wtf
- what goes into setting up a H/A meet?
- Wtf?
- what you think about this setup
- 2nd gen teg meet ???
- H/a Dyno Day!!!
- Camber Kits?
- Any s/c LS's out there?
- ? for all the turbo'd honda guys...
- Intake manifold and t/b
- Buy yourself a press...you'll be happy
- Final Fairwell to Honda/Acura
- Final Fairwell to Honda/Acura Tech
- New Toy..can anyone shed some light on the subject
- main relay?
- Blew my motor today
- Brakes Leaking?
- R.I.P EG Civic GSR-T
- Finally got it done!! (w/ Pics)
- shift linkage question
- Damn this fucking suspension....
- TECH: Flywheels, when is light... too light?
- what kind of rods and are they good
- Flywheel..How light is too light?
- DPFI to PGMFI?
- Help!!!!
- whos going to the race on the 26th???
- confused when it comes to ordering parts
- Where can I buy Wastegate Spring?
- turbo on ls vtec
- a/c in ls/vtec crx?
- cruise control
- ok HELP on turbo setup...
- car won't start :(???
- Integra head gasket
- bronze or black wheels on DA?
- Powder coat or spray paint??cheaper/better?
- what dizzy and ecu
- Ferrea Valve Train HELP
- Good place for body parts??
- Integra D16a1 Cams
- honda center cap question
- Need help with oil pressure guage!!
- bypass valve questions
- running lean?
- d15-d16vtec head swap
- supercharge or turbo
- throwing code (help)
- Quick Recaro seat question...
- ls/vtec... think this setup will last?
- stronger clutch master?
- car wont start
- bearings
- TECH posts?
- Faulty VTEC
- TECH: Fuel Injectors
- nothing like HF hatch
- Pics of the new super sleepR exhaust
- Anyone have a 4 wire o2 laying around for say $10-15$??
- Good place to get valve seals replaced??
- is this possible
- obd 1 vs obd 2 dizzy
- Fuel Pump Problem
- kamikaze headers?
- 86 civic 4 door 4 sale
- obd1 or 2 dizzy HELP
- Next H/A Meet - Dates??
- 95 Civic front suspension
- Thermal exhaust .. install and order from who?
- linkage problems....
- Integra + rain = soaked interior
- honda crx
- Integra dash in a EG Hatch
- idle prob driving me nuts
- All thanks to Frances...
- question about intake
- Tranny or Clutch?
- runin rich?
- Using a ls water pump on a high rpm motor..
- Who builds/sells engines??
- Apexi VAFC Questions
- fuel problem
- help me asap
- exhaust modification?
- vtec gos in and out rapidly
- timing adjustment
- long or short geared tranny
- Stock Teg Height?
- which dash gauge is this?
- Clutch Slippin?
- How can I make my tranny last?
- Srt-4 motor into a Eg hatch
- jdm distributor same as usdm
- info on some Vtec Cams!
- Need Help Please...
- Anyone have a tow dolly or flat bed???
- is this good enough for lsvtec
- pistons good for ls vtec?
- h22 in eg axle probs
- coilovers
- variable intake dealy
- ivtec
- Speedometer Cable
- ITR Transmission ..
- Integra Clutch? Best bang for the buck?
- 87 integra shifter ?
- cross threaded spark plug
- polishing a valve cover
- Rescheduled Dyno Day
- what to do next
- what is the probability of this happening?
- I cant get my rims to stick to my tires.
- Throwing a code 8
- Anyone Good with Soldering(boost controller install)
- Drivetrain experts: Get In Here.
- Question on injectors
- turbo LS
- anyone using an oil cooler on the honda/acura
- Ls head rebuild .. .
- CRX Opinion / Help?
- Need Help
- Need wireing help
- h22 in 93 accord ex
- axle wont come out
- Skunk 2 Products?
- ARP headstuds
