ok HELP on turbo setup...
ok ive been thinking, i dont see many f22a series motors being turbo'd, so ive been doing some research and things
just im still so confuded
planning on the t25 dsm setup (2g), im looking for something that i can run my factory a/c, yet having some hp gains but nothing to serious...turbo'ing looks so easy, but describing it is kinda wack!
AHHH ive been readin and researching things like crazy, but i dont understand it lol...
i know some crap needs to be redrilled to fit this exhauts mani to that exhaust mani...bleh..maybe its because im too damn tired and havent had a good night sleep latley, that i cant interpret anything...
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
i would go with a 14b (1G DSM) or a 16G. Both turbos will make more power than a T25 will and they are pretty much the same physical size.
i know i would need the O2 sensor housing and the 1g Exahuast manifold because that would work and its cheaper but flows crappier than the 2g, but i could port it, but i would have to get it redrilled to fit on my head, and i know i could use the stock down pipe on my car with a new flange(?) i think, pressed onto it, i dont think i would do that, but if fundage became tight until i could upgrade lol....then i would have to upgrade my fuel system and what not....
so say i where to use some 2g components and use the 14b with the 1g exhaust manifold?...or use all the 2g components(mani/o2) but use the 14b, because i do hear the 14b is better?
im kinda chopping it and doing it cheap, but im not looking for some major numbers...any other setup to use on this beast?...or hows it sounding?..lol
im pretty sure that the dsm manifold is extremely close to the f22 spacingon the head as far as exhaust ports go. with some minor mods you should be able to swing this,i have seen it before.
if the downpipe interferes, then just make a new flange and change it up a little
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
i didnt know the dsm flange would almost bolt to the f series head
i guess you learn something everyday
TR happily married crew-member #2
___________________
___________________
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
yeah, i was seriously wanting a H22a
but now i see them everywhere lol, still would like to swap, and boost ....but im trying a diff route now..boost my non vtec sohc!!
this will all be after a rebuild, would ya say run this on my stock motor?...@ 7psi?
hmm cause i would like to do this within the next month or so...just im still striving for info lol....thanx
some things im looking at
14b with all 2g components(ported)
external wastegate
boost controller
t timer
FMIC
blue top 450cc injectors
s-afc management
which fuel pump?
tryin to get me a list lol....
thanx
but now i see them everywhere lol, still would like to swap, and boost ....but im trying a diff route now..boost my non vtec sohc!!this will all be after a rebuild, would ya say run this on my stock motor?...@ 7psi?
external wastegate
boost controller
t timer
FMIC
s-afc management
which fuel pump?
thanx
Originally posted by Bull_Head360
this'll be bad ass when ur done
