bogging out at the begining of each gear?wtf
alright this thing has already got me fustraighted,only been happening a day.since i changed my o2 sensor,now it runs a lil better,i also adjusted my idle up a few hundred rpms,and now,when i start off ill rev it to 3k and when i start letting the clutch out it rapidly drops about to stall out then i give it some gas and it takes a sec then it kickes in,and does this in every gear.bad fuel filer,fuel pump???help..-Greg
check ignition (the simple stuff) then check fuel pump (the not so simple stuff)
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
enginle light is not on,after i put the o2 sensor in i reset the computer,and it hasnt come on since,maybe runnign on a bad o2 sensor for so long cloged my fuel filter?how much do those this run in price?
Fuel filters are cheap. Go to your local acura dealership... $8-10 bux.
19 bucks usually try that first sounds like a fuel problem but having abad o2 wouldnt cause your fuel filter to clog any more.
my second guess would be injectors or fuel pump or even a clogged Cat if it has one.
-J
-J
