pistons good for ls vtec?
Old Sep 4, 2004 | 11:22 PM
2ndGenT3g's Avatar
Default pistons good for ls vtec?
i found usdm pistons brand new with rings and a .25 bore what do i need to do with block if any thing?if u got somthin better let me know
||=|| ((O)) ||\\ || |D) //-\\
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
05 civic 4dr EX SE-SOLD!
08 Acura TSX_ 6mt
Old Sep 5, 2004 | 08:33 AM
Josh's Avatar
Dr. Doom
have it honed out .25 over by a machine shop. you'll also have to have a machine shop notch the pistons about 1 mm to get it to fit on the LS rods. i would also reccommend while you have the rods out, have them put in some ARP rod bolts.
Old Sep 5, 2004 | 08:36 AM
Josh's Avatar
Dr. Doom
i'm assuming USDM ITR's like his sig says.
Old Sep 5, 2004 | 08:46 AM
rangcrx's Avatar
engine building &best
i have a set of 2000 b16s that will make it even better stock bore and will fit your rods no machining i even have a set of rings with them only 800miles on the rings
i love AUTOZONE
Old Sep 5, 2004 | 09:43 AM
2ndGenT3g's Avatar
they are usdm type r pistons and dont the b16 pistons have a lower compression? how much let me know thanx
DB2-SOLD!
Dc5 Type-S-SOLD!
97 civic 4dr-SOLD!
08 Acura TSX_ 6mt
Old Sep 5, 2004 | 11:42 AM
2000CivicSi's Avatar
i thought b16 pistons raised compression. but i could be wrong
Old Sep 5, 2004 | 12:50 PM
TSX24L's Avatar
Pr3 raise compression.
Old Sep 5, 2004 | 09:41 PM
Bull_Head360's Avatar
currently breaking things
word, pr3 raises compression, thats whut i would run, and all you have to do to put in arp rod bolts (which i highly recommend, along with a proper break in for the motor) in, is drop the oil pan and take out the old and put in the new
sleepy hatch
**Looking for turbo kit for B-Series motors**
Old Sep 6, 2004 | 08:20 PM
mtber's Avatar
Use http://www.c-speedracing.com/howto/c...c/compcalc.php
To figure out exactly what configuration you want to use.
I recommend staying around 11.5:1
Some people preffer anything under 12.5:1
