Tail Light Problem
Old Sep 17, 2004 | 11:28 PM
Slo_Si's Avatar
$200 Motor!
Default Tail Light Problem
I have a 89 crx with a b16 swap. I recently took a trip down to Miami and unfortunatly i got into an accident. the whole driver side headlight, being made out of glass, shattered all over the place. anyways all the lights broke on the driver side including the corner lens, bumper light, and headlight. all of those and their bulbs broke. i was driving the car back up here and it started to rain and it was getting a little dark due to the clouds. so i turned on my lights and the clock dimmed and the instrument panel (gauges) lit up. everything was working fine until later on that night i left a friends house and nothing turned on. including the passenger headlight which was in perfect condition. i changed both headlight bulbs and they turned on fine. but still none of the gauges lit up or tail lights. BUT MY BRAKE LIGHTS TURN ON WHEN I HIT THE BRAKES SO ITS NOT THE BULBS. i know that the "sockets" for all the bulbs on the driver side got wet when i had them on and off. WHAT IS THE PROBLEM AND HOW DO I FIX IT, YOUR HELP AND SUGGESTIONS WILL BE GREATLY APPRECIATED.
THANK YOU...
Old Sep 18, 2004 | 02:39 AM
rangcrx's Avatar
engine building &best
for real? its a fuse your panal lights are on the same circut as your rear lights to help you so if your fuse blows you will no check your fuse i think its the last fuse on the bottom like #13
i love AUTOZONE
Old Sep 19, 2004 | 12:24 AM
Slo_Si's Avatar
$200 Motor!
I've checked the fuses all of them are fine.
- Officially Retired....for now...
Old Sep 19, 2004 | 07:16 AM
kender's Avatar
gadget man
check the contacts inside the bulb sockets on the crushed headlight and turnsignals, if the contacts got crushed together this may cause a problem.
U.S.S.A Crew Member #001
Old Sep 19, 2004 | 10:13 AM
Slo_Si's Avatar
$200 Motor!
Thanks, i'll check that but as far as i know i put a new bulb in the socket for the main low beam light (driving light) and it went in fine. i will check the others.
I am still free to any suggestions...
