Flywheel..How light is too light?
on the market for a lightend flywheel for my current project,i know lightend flywheels put more power to the wheels by eliminating all the weight of the fly wheel,but ive heard from some that if you go TOO light,you could also lose power,now im kinda sceptical about that statement but what i was thinking is the lighter,the more unreliable/able to break on you..help me out.-Greg
to me i would say it goes with your setup i just built a high high compression motor with a 8lb one and man it pulled so hard it was great BUT i used a act 6puck then i tried it with a stock disk it was tight and nice then i change it again to a 10.9 lb on just the stock one i did not like that one for some reason my rpm would rish for no reason so i took it off now im with a 12.2Lb with stock disc it catches so damn hard but takes that extra sec for my rpms to raise like with the light one,but im now going to rebuilt another motor for mid comprssion with a 9Lb flywheel and a streetStrip disc with a stock pullie and see how it is i guess it goes by setup ......tell us what you have or want
i love AUTOZONE
i love AUTOZONE
well if your running stock motor Ls i would say 8 is good and i have used 3 different kinds from act exedy and unknow THAY ARE ALL THE SAME i think there was a fight over aluminum billiet and steel just find a good deal on ebay
i love AUTOZONE
i love AUTOZONE
First off, you mention running a lightened flywheel. I wouldnt suggest this what so ever, I'd suggest an Aluminum Fidanza 8.5 pound fly. I know everyone else probably meant the same but you can lighten an OEM fly. Also this is what I run in my set up and love it.....It's actually Keith fly from his GSR Turbo hatch
Had to keep it in the family.
Kris
Had to keep it in the family.Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
Guest
Posts: n/a
I like the idea of lightening the stocker.
I wish I could find more research on flywheels and how the affect the motor. Less reciprocating mass on the engine should free up a few extra ponies, but it also affects gas mileage, and driveability so Im told.
I would think running too light of a wheel wouldn't really do anything. Although Im told otherwise. Im curious if anyone has any definitive information on this.
I think I will quest for a new Tech article about this subject.
running too light a flywheel makes taking off very difficult, less weight means less force to slow down (and vice versa). billy's wrx for example, had a lightened flywheel, and he had trouble launching because the car would bog, went back to his stocker and it is fine and dandy. my advice is find a happy medium, tried and true things...ive driven a del sol with an act 6 puck clutch and heavy PP, with some insanely light flywheel (wanna say 6lbs) and it was either feather the clutch, which was hard to do period, or raise the rpms some more and feather it a little less. but like i said, its something your going to have to feel out.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
