Flywheel..How light is too light?
Originally posted by Sneakin Deacon
running too light a flywheel makes taking off very difficult, less weight means less force to slow down (and vice versa). billy's wrx for example, had a lightened flywheel, and he had trouble launching because the car would bog, went back to his stocker and it is fine and dandy. my advice is find a happy medium, tried and true things...ive driven a del sol with an act 6 puck clutch and heavy PP, with some insanely light flywheel (wanna say 6lbs) and it was either feather the clutch, which was hard to do period, or raise the rpms some more and feather it a little less. but like i said, its something your going to have to feel out.
TR happily married crew-member #2
___________________
___________________
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Guest
Posts: n/a
Originally posted by `92CXhatch
the flywheel wont transfer the TQ as well in a launch... being that it weighs less it will have less inertia...
now remember some physics...
A body in motion will stay in motion unless an equal yet oposite force acts upon it...
so think about this... you rev your motor (flywheel spining) you release the clutch and the "oposite" force being your tires on the road (traction) with the lighter flywheel (if you have traction) the motor will tend to bog easier, or if you over rev to get over the bogging you will spin...
now with the stock flywheel... same situation... you will be able to launch lower and transfer initial TQ easier (getting off the line)...
-Keith
-Keith
https://www.tamparacing.com/forums/s...ght=dont+sleep
Originally posted by tampa railroad hobo
yeh, with a lighten flywheel, u have to shift a lot faster or blimp the throttle a bit since the revs will drop faster than a stock flywheel.
even if the revs drop, they come right back up if your clutch doesnt slip once its engaged. for example 60mph is a mathematically set RPM in each gear...a lightened flywheel doesnt change your gear ratio.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
if it takes you that long to shift, that is driver downfall, not the cars.
aint gotta use the clutch to shift during regular cruising, so the dropping rpms wouldnt be a problem...for me anyways, i rarely use the clutch.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
trucker shifting woot woot!!!! hahahaha i can do it into 5th gear but i dont want to try it that often ... lord knows what it is doing to the car
TR's drive my car more than 2500 miles in less than a month crew member #01
I think he means he uses the engine rpms to slip into gear. say at 3rd gear 7k pop out of gear and shift into 4th when the rpms drop to like 4.5k ( not sure on the actual rpm values). it takes some skill and until you get it right a whole lot of grinding but it can be done. I used to do it on my s15 pickup, but haven't taken the time yet on the honda.
