vtec gos in and out rapidly
Old Sep 6, 2004 | 09:47 AM
CARNAG3's Avatar
ROTM March 2013
Question vtec gos in and out rapidly
b16, no vafc, non chipped ecu, 48psi fuel
at 4800 when vtec is supposed to engage it comes on and then cuts out rapidly and then at about 7500 rpm it finally engages properly.
i got a new screen and gasket for my v. solenoid. and still same problem
my oil level is full. i messed around with the fuel pressure and same result.
any ideas????
Old Sep 6, 2004 | 09:58 AM
mtber's Avatar
Sounds like an oil pressure issue.
It could be a serious problem or it could be something as simple as a bad vtec oil pressure sensor etc..
Old Sep 6, 2004 | 10:06 AM
brax90si's Avatar
is the solenoid properly grounded?
Old Sep 6, 2004 | 10:12 AM
CARNAG3's Avatar
ROTM March 2013
its grounded to tranny ground wire
had bought a bran new oil pressure switch from honda so its not that. could it just be a bad solenoid
Old Sep 6, 2004 | 01:18 PM
mtber's Avatar
If your oil pump is going to shit... and not creating enuff oil pressure, this can cause vtec to disengage etc..
Old Sep 6, 2004 | 02:38 PM
CARNAG3's Avatar
ROTM March 2013
just put a new head on the car. everything worked before the head swap.
any ideas on that. could a head some how have the vtec mechanics damaged inside?
Old Sep 6, 2004 | 06:27 PM
Bull_Head360's Avatar
currently breaking things
id say its the solenoid if your oil level is fine
sleepy hatch
**Looking for turbo kit for B-Series motors**
Old Sep 7, 2004 | 01:27 PM
Old Renegade's Avatar
Cool Runnings
check your v-tec soleniod and pressure switch connectors could be dirty thats was the remedy for mine sfter having the same issues as you.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Sep 8, 2004 | 01:32 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
mine did that when i tried to hook up a nos solenoid to it so the nos would hit the same time as vtec but it didnt work vtec snapped at 6100 where it was supossed to and then shut off at like 6800 or so and no vtec all the way to 8600 limit
Old Sep 8, 2004 | 08:03 PM
CARNAG3's Avatar
ROTM March 2013
missing knock sensor...could this couse the vtec to rapidly go on and off?
