Anyone know how to install an shift-light properly?help me out.
Old Sep 16, 2004 | 06:07 PM
DA92driver's Avatar
Default Anyone know how to install an shift-light properly?help me out.
i ahve an auto-meter pro shift-light comin and i need to know how hard/easy it is to install...thanks in advance.-Greg
Old Sep 16, 2004 | 06:56 PM
kender's Avatar
gadget man
should be fairly straight forward, most likely red wire to either constant 12v or more likely to acc ( key on position) black to ground, and a third wire that taps into the rpm signal wire from your ecu. I have a razo shift light that is that easy. 3 wires.
U.S.S.A Crew Member #001
Old Sep 16, 2004 | 06:59 PM
DA92driver's Avatar
im am dumb when it comes to woring or electronics...lol
Old Sep 16, 2004 | 08:27 PM
B20VTECpoweredEG's Avatar
More Boost>Traction
Dont go near your ecu for the connector, go to the drivers side engine compartment, look the corner for a junction connector, tap into the solid blue wire in it. If you have a voltmeter, you can back probe it, it will only have ac current. Its alot cleaner that way.
MY HOME:
Originally Posted by 99AtlBlueGT
I would but I wouldnt fit in. I am out of high school and don't drink in parking lots anymore.
It is lame in the NPR/Hudson area, there are some crazy fast cars but no one comes out....we are on a "Racing" forum and all that comes to the hudson/mitchell rd. meets are like 4 cars that actually race, 32 spectators that follow everyone in there Geo's and 15 underage high school alcoholics.....
Old Sep 17, 2004 | 04:15 AM
Old Renegade's Avatar
Cool Runnings
to hook your tach up i thought you get the reading from the blue wire from your dizzy at least thats how i got mine and it reads great.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Sep 17, 2004 | 10:44 AM
More Boost>Traction
where do you think the blue wire goes? to the junction connector on the drivers side firewall, then to tach inside of car.
MY HOME:
Old Sep 17, 2004 | 11:41 AM
accord95's Avatar
USMC
i have the autometer shift light in my car, and have hooked them up on 3 other cars. it has three wires comming off of it,
red=(hook this up to your switched ignigtion, not constant 12v). when you get the shift light it will come with some little flat connectors. in my fuse box under the dash there are connections that fit the connector that it comes with, just plug it in. i used a pin light to see which ones had power when the key was turned to the acc position.
black=ground obviously, mine is hooked up to the frame under the dash.
green= this goes to the negative side of the distributor(usually a blue wire). on a couple of the cars i've done, i opened the distributor and hooked it up to the negative terminal. on the last two cars i did i bought this nice little connector that connects the wires without splicing them.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Sep 17, 2004 | 11:54 AM
Cool Runnings
welll my car did not come with a tach so i was just going by what was told to me and was just trying to relay the info, plus there is other stuff you got to do to make the tach work like which wire in the back of it to cut think it got to do with the pulse or something of the engine not sure but if you cut the wrong one it will not work right. you have to go according to your motor wether it be four, six, or eight cylinders. also got my tach light to come on only when i turn my lights on rather than it be on all the time.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Old Sep 17, 2004 | 11:58 AM
accord95's Avatar
USMC
yeah, but you dont have to worry about that crap on a shift light. the shift light only has three wires comming off of it.
___________________
Old Sep 17, 2004 | 12:10 PM
Cool Runnings
i guess it depends on what brand of tach you get. mine has four wires(positive-red, negative-black, sender-green, then a white wire for the lights for the tach then two small wires that the instructions say you got to cut one if its a four cylinder. the small wires are brown and blue i think cut both for a v-8 brown for a six and the blue for a four. my tach is a autometer 5" monster tach phantom series with shift light.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
