Damn this fucking suspension....
Old Sep 11, 2004 | 08:42 AM
Josh's Avatar
Dr. Doom
Default Damn this fucking suspension....
Down to the last damper and spring and it is just kicking and screaming to go on.
we have the rear lca almost completely disconnected from the car. we've got the damper lined up and bolted into place, now we need to get the LCA completely back onto the car and we're haing trouble with the lower bolt, turning and turning and turning and it's not catching on the threads. anyone, any ideas?
Old Sep 11, 2004 | 08:46 AM
TSX24L's Avatar
One iam sure of many methods are using a mallet to hit the head of the bolt into the first thread then applying some pressure with the rachet on the frist few turns tightening.
Old Sep 11, 2004 | 10:06 AM
Bull_Head360's Avatar
currently breaking things
wow, that sounds like a great idea....
sleepy hatch
**Looking for turbo kit for B-Series motors**
Old Sep 11, 2004 | 10:54 AM
JamesH's Avatar
I'm just her baby daddy
make sure the lca is totally lined up to where the head of the bot will match the hole and will catch threads. if youre having a hard time keeping the lca up there try using another jack to help position the lca right with the holes.
Old Sep 11, 2004 | 10:55 AM
JamesH's Avatar
well why dont you tell how to do it right instead of just making a useless comment.
Old Sep 11, 2004 | 11:53 AM
Josh's Avatar
Dr. Doom
finally got it in guys, i just used a crescent wrench to manipulate the LCA, finally got the bolt to "bite" thanks again!!!
Old Sep 11, 2004 | 12:27 PM
accord95's Avatar
USMC
it is a great idea if its not too far off from starting to thread. have you ever lowered a car? i've lowered probably about 10-15 cars(5 of my own) and i've done that before.
the last time i lowered the accord i had to use an extra jack to get it to line up.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Sep 11, 2004 | 01:02 PM
JamesH's Avatar
thats what i always do, ive probably touched the suspension on about the same amount of cars.
Old Sep 11, 2004 | 01:15 PM
Josh's Avatar
Dr. Doom
yep, i just used a hydraulic bottle jack to get the job done.
Old Sep 11, 2004 | 01:56 PM
TSX24L's Avatar
If you put some thought in on how that works, If your holes are lined up and the bolt doesn't exscatly go all the way to last one. Not a hard hit but using your judgement it get the bolt to the point were you can start tightning it with the rachet.
Its a method I have used and it has worked fine. Using the other arm to kinda move the lca around up or down while tightning. Just thought I would throw out a idea like he said. I know that the lca are a pain in the ass when your doing this stuff in your garage and air tools are not there.
