Throwing a code 8
Old Sep 3, 2004 | 11:36 AM
Stephan's Avatar
Default Throwing a code 8
i dont know jack shit about wiring and i am trying to figure out how to fix a code 8 on a jdm first gen b16a in a crx.....i knot its a TDC code but honestly i have know idea what that is.....thanks for any help in advance
DSM Part Out
Old Sep 3, 2004 | 12:34 PM
40ozCasualty's Avatar
shift_lock
Its a Top Dead center sensor, Its in the distributor. Time to get a new distrbutor.
Old Sep 3, 2004 | 12:42 PM
Stephan's Avatar
well i just swapped my motor out of my crx to one with a clean title and its giving me this code......it worked fine in my car......could there be something wired wrong????
DSM Part Out
Old Sep 3, 2004 | 02:38 PM
KJ's Avatar
KJ
bored at work
Yeah sounds like the TDC wires are backwards.
Old Sep 3, 2004 | 02:41 PM
Stephan's Avatar
which wires are they? also do i just need to switch them around?
DSM Part Out
Old Sep 3, 2004 | 03:14 PM
shift_lock
I thought a code 9 meant that the TDC sensor wasn't wired right? My CRX, Throws a code 9 because the copper wire thats supposed to be around the TDC sensor came apart.
I could be wrong, But I suggested checking the distributor for copper wire wrapped around the shaft. Might aswell check the wiring on that aswell.
Old Sep 3, 2004 | 03:49 PM
rangcrx's Avatar
engine building &best
is yours a SI or did you convert?
i love AUTOZONE
Old Sep 3, 2004 | 07:24 PM
Stephan's Avatar
it had a ls and i put my b16a in it
DSM Part Out
Old Sep 4, 2004 | 07:29 AM
Stephan's Avatar
ok well i fixed the problem....it was a wire that came loose at the ecu.....but now while the car i have car running and the door open and the ebrake on the dash lights like flicker along with the clock......also i have a two prong sensor and a one prong sensor on the back of my block and im not sure what color wires go to which sensor.....
DSM Part Out
Old Sep 8, 2004 | 06:10 PM
89crxsir's Avatar
86-98 Civic
97-98 CRV
85-98 Prelude
94+ Integra
TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
SEE NO EVO HEAR NO EVO!
If i put half a tank of Shell V power, and half a tank of Chevron with Techron. Will i get v-tec??
