- installing new rings....need help
- idle issues
- boosting a d16z6
- Wired new injector clips...now cel
- what is the difference between the b18a and b18b
- "Q" A/C Help
- Two thumbs up for Skunk2's customer service
- turbo installed doesnt make whistling noise?
- Tranny housing replacement
- SOHC VS. DOHC gas mileage
- 91 accord wont stay on ...
- a/c bracket
- Spark Plugs???
- need advice!!!!wut should i do???
- new to honda forums
- McCrananor Motorsports???
- battery dead?
- Royal Purple MT fluid
- Integra 5 lug conversion
- dash
- What to do next on my CRX!?
- Whats The Deal With Ebay Turbos???
- Drag Radial And Slicks Only Event At Bradenton Sunday, April 29th (Spots Available)
- HELP***99-00 cicic si A/C ***HELP
- obd0 to obd1
- ?question ?
- Surging idle help!!!!!
- what will fit/work?
- arp rod bolt question
- breather filters (on valve cover)
- Conversion
- Nos ?
- Ls Turbo-mounting Battery In Trunk?
- ANother Vtack question
- best place for used parts
- need my ecu tunned
- ls/vtec questions
- Window guards?
- How much to make my auto a manual?
- Vertical Doors
- Brand tool of choice
- Shift boot question?
- Civic/ integra armrest top?
- DC5R Seats
- rpm gauge problem
- is TPS replaceable
- Hey does anyone have a set of spring compressors i can borrow...?
- Spring Recomendations?
- Lip Kit
- About head unit to the eg civic
- B16 Clutch Situation
- 5 point harness
- looking for a recommendation for a good tuning shop...
- Sealant/glue to seal the new weather strip?
- Hybrid Intake?
- Even More Pictures From The H/a Meet!
- please help!! brakes..
- how do you wire up dx to si
- More Pics Of The Meet
- twin loop muffler WTF!?
- need ideas for this accord
- Ls Vtech Help
- ac help!
- Is it possible to swap a b18a into a CR-V?
- AC help
- anybody wanna help me put in a y8
- header
- hx distributor wiring
- Vtec Solenoid Situation!
- pass axle on 94 dx
- wiper blades speed malfunction
- rear lower conrol arms
- LSD's
- emblem question
- help with a/f gauge, oil temp & oil press gauge
- acura integra car alarm install ???
- Turn signals
- Does lowering put stress on Automatic transmissions...
- good exhaust for an ef
- what size socket 2 remove sending unit
- Blox Or Skunk2 Intake Manifold????
- What are your thoughts on NAPA?
- Tsudo exhaust retail source ???????
- EK power to crank window conversion
- Idle?
- center caps
- stupid question for 95 acura ls
- RSX help
- Best Tranny For My Car
- axles for integra question for u honda/acura peeps
- Need a shop that can install gears..
- Does anyone here have a cold air intake box....
- question about the lsd from obx racing......................
- GSR F.P.R. question
- To all honda gods... plz help.... if u can LOL!
- ebay fog lights???
- vtec cams?
- new distributor
- tranny whoas
- 1gen CRX, any part web sites?
- did it myself corner lense
- why does vtec kick when ever it feels like it
- need some help.. clicking noise
- quench pad??
- Accord Vtec solinoid??
- lame rsx
- Good Tires?
- Spring Pin
- Q about Ls intake manifold.
- B16 swap help
- dx to si wire up, need someone to fix mine.
- ECU chipping
- reving at idle
- NEED HELP!! gauge cluster
- 1996 to 2000 a/c
- Custom spark plug covers
- please share your experiences.....
- Any h22 in eg hatch guys in here?
- Help with window
- eCtune a new EFI Honda Tuning Solution.
- Four door curb weight
- Disty Help
- B series and D series AC question
- cluster question???
- Prelude JDM Climate Control
- h.i.d. ??????
- AEM Tru Time Cam Gear ?
- Integra HID's! Need help!
- Difference in bseries wiring harnesses
- 91 ls type r header Q?
- place to get oem honda parts
- Tinit Removal??? Anyone????? LOOK????
- Got a Problem!!!
- need new intake manifold for my 89 integra/stockD16
- Dc2 Issue
- CV Joint
- Horrible grinding noises... 95 accord..
- Are Gsr And Ls Tranny Mounts The Same
- Need Help With Steering Wheel Column
- tuning?
- Is there anymore tech in here?
- vtec dosn't kick in
- Civic wont start
- carbed 91 civic white smoke . .
- skunk cam
- Compression Question...
- Distributor Question
- Adj. Cam gears.....
- MiniMe Correct Dizzy?
- gsr fuel pump in crx?
- big problem.....!!!!!!!!!!!!!!!!!
- wheel spacer?
- VTAK Controler
- Need Indo On My Eg
- miss after new headgasket
- rear ef camber kit ????????????????????????????
- Will double din CD player fit in 94 integra....?
- jdm headgasket
- lma's
- valve cover?
- Does eg civic has a ac fuse under the dash panel?
- Why does my interior fuse keep blowing?
- type-r head???
- adding 3rd brake light?
- Will a gsr tranny bolt up to a b18b1?
- Needing Mad Help
- rough idle need help
- tranny problem
- EF/CRX body panels?
- Writeup: 05 RSX DASH and K series swap in 95 Integra!
- need help on 90 crx
- my cargo doors wont open!
- map sensor for boost and ecu tunning?
- pictures of my eg interior before and after
- Another coolent problem..??//?
- clutch cable question?
- how are cylinders numbered in rsx
- a/c in 99 civic si w/ type r block
- What motor should i use??
- nitrous / compression
- eg cluster
- Official H/A Track Day 17 Recap Thread
- ep3 civic si
- ek motor into eg questions help
- roll cages
- Need Help...
- johnny race car
- need help with aem cam gears
- ef problem
- integra temperature question....................
- GSR guage cluster in an EG
- Questions: ZC Oil Pan on d16a????
- I Know This..
- looking for:pre-built b-series short block
- throotle body and manifolds
- quick question replacing rear struts/srpings
- Acura TL question
- ---- Track Event 17 Is Today (March 31st) From 3:00 - 9:00
- JDM d15b into Ek
- tires
- spark plugs
- anyone bored and wanna see a funny video
- Problem with Cylinder #4
- what car /motor do p30 pistons come in ??
- Overheating
- fuel problems
- Hell has frozen over and I'm about to finish a car for myslef....
- Any diff bet 1.5 non-vtec inj vs 1.6 vtec inj
- help on 87 crx
- d16y8 into eg questions
- Just change block now engine runs but wont turn on with key
- Blox Cams
- How to make your civic faster?
- possibel power?
- does anybody do leather dye?
- How to mkae your civic faster?
- 87 d16a1 into ef hatch
- GSR rods on LS crank?
- 94 ls transmission axle seal?
- Help me choose!!!;ldkjfsjdfkl
- pistons
- what motor????
- need help asap exhaust ?
- Motor Swap Options
- new swap chugs/bogs
- suspension
- ek side skirts on a 94 civic
- 450 dsm clip question
- d16y8 spun main bearing
- camber kit needed ?
- turbo a b18b1
- need some help...!
- Ls Crx Broken In Brandon
- my stinking window
- eg exhaust question
- locked up my b16
- HELP Car not goin into gear HELP
- For those who look for radiator....
- good site to order OEM parts?
- getting a new motor?
- Car randomly not starting/turning off !!FIXED!!
- Light Blue....white Smoke????
- honda beat ???
- Acura head-p75-6
- Can anyone tell me the best place to buy an OEM factory short/longblock?
- acura rsx intake
- \\\\ Last Day To Get In On Track Event # 17 And Switch Names \\\\
- What would you do???
- swap question i need answer
- Foglight Question
