Royal Purple MT fluid
There is also a discussion on Honda-tech.com
I am getting mixed reactions. I lover there oil, but I was wondering if anyone is using this? And if so did you mess anything up?
I am not concerned with weather or not you fixed your grinding problem but more if you felt in difference in the feel of the tranny.
Cburke.industries.
Custom suspension bars, metal fabrication.
Cburke.industries.
alright, 1st off...if there is a grinding problem...a fluid change will not fix the damage already done to the gear or synchro whichever the case may be.
also, it isnt going to change the feel of the shifter. the only thing externally that will is the linkage itself and the shifter assembly.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
I don't mean shifting.
and if you have a slight grind in your tranny synchromesh does help that.
Cburke.industries.
Cburke.industries.
probably because its thicker and adds friction which will bring the gear up to speed slightly quicker..but the synchro is already worn at that point. the fluid is just a temporary band aid.
and if you didnt mean shifter...what else is there to feel about the tranny?
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
You can feel the difference. A trans that shifts smoothly without grinding, "feels" better than one that requires more force and grinding to swap gears.
A new set of honda syncros on a freshly rebuilt trans feels better and shifts with less force with syncomesh fluid than standard motor oil. There is no question about it in my experience. I understand it helps shifting with badly worn syncros as well, though obviously it doesn't "heal" them.
royal purple synchromax...i put it in and loved it, haven't seen any negatives yet....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
..baffling..
thats so odd that they would run a multi viscocity lubricant.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
