dx to si wire up, need someone to fix mine.
Old Apr 10, 2007 | 07:54 PM
2qk4u's Avatar
Default dx to si wire up, need someone to fix mine.
tampa area.
i cant for the life of me figure out what is wrong with my car, did the dx to si wire conversion and its my first time messing with it, i got the car started once but now it wont start, im getting code 16 which is injectors and code 3 i thnk which is map sensor i cant figure out where all the damn vacuum lines go either.
need to pay someone who know something about this to help me out
has to be on a saturday though becuase im in orlando but car is in tampa and i can only get back on saturdays.
just hit me with a pm or reply
Old Apr 10, 2007 | 08:35 PM
Hater's Avatar
Free base cocaine
do si's run a resistor box? im not that keen on ef's
what ecu are you running?
Old Apr 10, 2007 | 09:06 PM
My Honda Is Slow's Avatar
No really,....it is
yes they do. the dx model ef did not so you need to add one into the si conversion
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Apr 11, 2007 | 07:45 AM
2qk4u's Avatar
i have a whole 91 teg swap that i put in resistor box everything.
the car started before but now i cant get it to start again.
i know i have something wired wrong or not hooked up.
its been like 2-3 years since i did a swap im so lost
Old Apr 11, 2007 | 08:37 AM
elitist's Avatar
TR Balla Donor Supreme
the DX model EF DID NOT come with a resistor box, it was dpfi not mpfi. If you don't have a resistor box then it's not gonna run.
Old Apr 11, 2007 | 10:54 AM
No really,....it is
thats what i said..............but yes he is right also^^^^
Old Apr 12, 2007 | 06:02 PM
2qk4u's Avatar
Old Apr 12, 2007 | 08:36 PM
elitist's Avatar
Originally Posted by 2qk4u
We can't help you if you don't respond to our questions. I just wired my girlfriend's 91 DX to MPFI, so I know how to do it just need to know
A) are you running a resistor box
B) did you repin the ecu
C) what write up did you use?
D) What wiring harness are you using for a donor harness?
Old Apr 13, 2007 | 04:44 AM
No really,....it is
hes waiting for answers to magicaly type themselves.
Old Apr 13, 2007 | 06:51 PM
2qk4u's Avatar
YES I HAVE A resistor box. i have a whole swap from a 91 teg. i have the DX harness that came with the car(88civ). im using the write up from honda-tech or someshit i know its right. and i have done all the wiring im just getting 2 or 3 codes
code 16 code 3 and i forgot the other
but code 16 is injectors so something is not right with what i did.
the car has started a few times just wont stay running long.
