dx to si wire up, need someone to fix mine.
yes the dx to si does suck your first couple times. as a matter of fact i still hate it. where do you live maybe i can come by and take a look at it for you if your close or something
What does it do while it is running...does it sputter or anything like that? I know when the swap to b-series was done on my EF is threw code 16 for the injectors because two of them were bad. Would you be able to try a new ECU to rule that out because when we did my friends h22 swap into his prelude the ecu was bad and caused running issues (went through 2 ecus already and still waiting for another one to come in).
pull out injector see if there spraying or if you constantly getting gas threw them most of the times when EF's sit they wont run becuase there not getting gas correctly , and do like custom240sx said and try another ecu , are you running a pr4 rite
._________________________
yeah im pretty sure the injectors are wired up right the car will start just wont stay running ima pull them out and take a look at them.
and i already tried a differant ecu and a differant main relay
the car was sitting for about 2 years so they might be clogged.
i already had to change the fuel pump out, that shit was rusted to hell and that was a bitch job first fuel pump i had to do, all the hoses and shit were so stuck on cuz car is 20 yrs old.
ya its a pr-4 i got a swap from a friend who rolled his car it was running before the crash and he wasnt goin that fast it wasnt really bad accident.
nah i didnt even think to change the filter and shit ima do that when i work on it next and chek the injectors. its always good to get other input cuz i forget alot of shit i can check out
yeah bad gas can cause non starting. or poor starting. also if this rust your talking about is THAT bad you prob have shit in your tank like what was said. so fresh gas change your filter, pull your injectors and make sure there spraying and make sure its not brown shit coming out lol
