is TPS replaceable
is the TPS on a ITR throttle body replaceable? My TPS is starting to go bad, and when i took off the TB to check it out i notieced their are 2 bolts holding the TPS on, but there are no heads to the bolts. If they make replacement TPS's will I have to drill the old bolts out? On the top of the bolt(visable from top of TPS), it looks like their is some kind of ring, or clip holding the TPS on.. Sorry for the long and probably confusing post, im just trying to be descriptive. TIA
Autoparts store dont sell them seperately neither do most people since they're a pain to get off and you shouldn't just bolt the new one on you have to test it and make sure its getting its giving correct voltage and no throttle and full throttle
You can buy a used throttle body from anywhere between $20-$150
Ricky
Ricky
its easy get a flat head and put it on their in the direction to turn loose and tap on it and they come loose
._________________________
make the slots in the screws and loosen it. Its really easy, then call me i have like a billion tps's 352-346-5199 derek
1998 crv daily beater
+1 Put a grove in it & use a flat head or start to drill it & then once the bit starts to bite turn the drill in reverse & try to get it to start them out. I can get you some oem screws that go in the tps. They have a head on them that you break off after you tighten it down..
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
