turbo installed doesnt make whistling noise?
I Installed It With No Charge Pipes Connected. Just Wanted To Make Sure Turbo Was Working Properly. When I Give It Gas You Cant Hear The Turbo Whistling (the Airplane Noise) Is It Because My Charge Pipes Arent Connected?
Can't spell strength without tren
AAS...It's whats for dinner
You are going to destroy your turbo running it with no charrge pipes. Stop doing that immediately!!!!
Gracie Barra Clearwater
From what I know to check if your turbo is working properly this should be done before installation:
You turn the turbo manually by hand to make sure there is no friction stopping it from turning smoothly and that it does not bobble when you turn it
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Wow...
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
bye going turbo your going rite, but your wrong hahah
._________________________
is it a brand new or use turbo , what kind is it, did you purchase a whole kit or not , y didnt you wait and hook up the whole kit?
I Hooked Everything Up To Make Sure My Seals Are Still Good. Iv Had It For A While Now. Why Is It Bad To Run The Turbo With No Charge Pipes (kj) All The Oil Lines Are Hooked Up. And I Dont Drive The Car Everyday
yah like chi town brat mentioned check the turbo for any shaft play and as mentioned above running it without charge pipes is a bad idea.....
