Distributor Question
Old Apr 6, 2007 | 06:22 AM
Yellow Rocket's Avatar
The Big Diehl
Default Distributor Question
Ive Got A 91 Crx With A 90 Block And A 93 Head(d-series) And Its Leaking Oil From The Distributor So I Replaced The O-ring On It. It Is Still Leaking So I Went To Hondaland And Talk To A Guy Who Said It Is Because The Head Is Obd1 And The Distributor Is Obd0. So My Question Is Is That True, And How Would I Go About Fixing This Problem.
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Old Apr 6, 2007 | 10:55 AM
Unless there is some wobble when you push in the distributor, it
should not be affecting an oil leak.
When a new o-ring doesn't seal, some people take the red high-temp gasket sealer, and apply it with their finger into and
around the rubber o-ring.-Bob
Old Apr 7, 2007 | 08:30 PM
TSX24L's Avatar
there is a seal inside the distributor sub assembly that is known for leaking oil also. You can replace just that one seal for like 8 bucks from honda if they still sell those seals seperatly. 9/10 that is what your problem is. That or find another sub-assembly that doesn't leak oil. My opnion is to go see if you can get a new seal and replace that part.
*should have stated this first, pull your cap off and see if oil is inside the cap or leaking around the cap area, that is usually a sign of that sub-assembly seal leaking oil.
Old Apr 8, 2007 | 08:37 AM
hondachris1994's Avatar
hatchback1994
my dizzy had the same problem, I just put some rtv sealent around the mating area, and havent had a problem since
Old Apr 8, 2007 | 03:57 PM
The Big Diehl
ok so rtv sealent it is, thanks guys
