Spring Pin
Can someone give me a link to a website that I can order these damn things from. I can't seem to find them anywhere on the web and I don't have time to drive to a honda dealership to order the "bitch" in. I think the name bitch pin refers to getting it out, putting it in, and finding it...basically everything to do with this pin is a bitch (I know that sounded sexual to an extent). Thanks ahead of time.
good luck with that, ur better off going to a junkyard and "carefuly" removing one, g/l with the rest of that its pretty much down hill, shit id be on the look out for a new tranny lol
Well I just ordered in prothane shift linkage bushings, new short shifter, and new shift linkages for my ls swapped ef hatch. Therefore I need the new pin to install the new linkages. Does anyone know if the honda dealerships usually keep these things in stock because I might be able to just send a friend to get one for me.
My friend told me that but I figured that the part would need to be oem honda or it would cause shifter slop. So any hardware store would probably have them...ie. lowes or home depot?
i dont see why not? they should work as long as its the same size as the OEM piece
1992 honda civic cx 2.0l
steeeeerrrrnss are gone
http://www.myspace.com/drew_doeboy
Nikon D50 w/ kit lens / Tamron 70-300mm DI LD macro AF/Nikkor 50mm 1.8f/Nikon SB-600 speed flash
Well I think oem is 8mm since you use an 8mm punch to knock them out. One more question...when you install these since they are longer than oem I would have to grind them down a little, well the question is do I leave enough so I can mushroom the edges of the pin or do I grind flush and just slip that metal clip over it?
