what is the difference between the b18a and b18b
my friends doin a swap in his civic eg and would like to know what the difference is between the b18a and the b18b. let me know guys. thanks
B18A1
Non-VTEC - 1.8L DOHC Inline 4-Cylinder N/A Engine
- Found in:
- 1990-1993 Integra RS/LS/GS (DA9 [coupe] and DB1 [sedan])
- Displacement: 1834 cm³
- Compression: 9.2:1
- Bore: 81 mm
- Stroke: 89 mm
- Power:
- 1990-1991: 130 hp (97 kW) @ 6000 rpm & 121 ft·lbf (164 N·m) @ 5000 rpm
- 1992-1994: 140 hp (104 kW) @ 6300 rpm & 127 ft·lbf (173 N·m) @ 5200 rpm
- Transmission: A1, S1 and YS1 (mostly 92/93)
- Non-VTEC
- Found in:
- 1994-2001 Acura Integra "RS/LS/GS" (DC4/DB7)
- Displacement: 1834 cc
- Bore: 81 mm
- Stroke: 89 mm
- Power:
- 140 hp @ 6300 rpm & 130 ft·lbf @ 5200 rpm
- Transmission: S80
if its an EG hes gonna wanna go with the b18b swap also because it has a hydro tranny on it has well and with the 94 up integra mounts it drops rite in
._________________________
to add on to robins, hasport makes a hydro/cable conversion, and i never liked the feel of the pedal with it but it did its job, i know sometimes you cant always get what you want, and if your left to use an a1, improvising is necessary.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
