AEM Tru Time Cam Gear ?
Old Apr 9, 2007 | 11:02 AM
CivicRacingFL's Avatar
Dorado, PR
Default AEM Tru Time Cam Gear ?
i have a d16z6 with headers, 2" exhaust, long cold air intake, what will be the best timing using the aem cam gear that i will be installing soon, degrees on retard or advance
Old Apr 9, 2007 | 12:54 PM
envee's Avatar
Green with Envy
none. stock motors won't be helped by cam timing. 2" exhaust and intake don't constitute the use of adjustable cam timing.
http://www.cardomain.com/ride/2931273
'06 Mazdaspeed 6
L3-VDT
'02 S2000... Sold
F20c
'93 Civic dx... Sold
B18C1
'95 4dr. GSR... Sold
B18C1 Supercharged
'95 LS... Sold
Originally Posted by shamoo
I have no problems punching a 10 year old in the face if they dented my car with intent.
Old Apr 9, 2007 | 01:32 PM
Maybe, just maybe, you can get just a smidgen more power than the other guy by increasing valve overlap by 1-2 degrees each way, and still not have the valves touch the pistons. The usual disclaimers apply,
and I would check all my clearances BEFORE I do a final assenbly
of my motor.-Bob
Old Apr 9, 2007 | 06:24 PM
sleepinsol's Avatar
starting over
u are wrong on the stock motor not getting any benifit from timing. i did it on my ls swapped del sol. internally stock with header intake and exhaust, i slapped some cam gears on and set them the way a friend of myne told me to. hes a local tampa guy that chips ecus n stuff (his name is kenji if u have ever heard of him). any ways, i set the gears at +2 on the intake and -1 on the exhaust, set the dizzy to 18 degrees of timing and put premium in a stock ls motor, and the car woke up. it wasnt like spraying or boosting, but it was a notable difference throughout the whole rpm range. id say, go to his site Kenji's ECUs and Conversion Harnesses and send him a message askin him what he recomends (im not familiar with single cams enough to tell u). if anything, u may want to get a header and a bigger exhaust first, but ull still benifit from the timing. granted, bigger cams, more mods, and a better tune would help in these benifits from timing, but saying that stock motors dont benifit at all is a lil overboard. a little more over lap is better than none. ask around or find a tech book to c where to set the gear, make sure u set the distributor right, and ull notice a difference. good luck and email me if u cant get ahold of kenji, n ill ask him.
Old Apr 9, 2007 | 06:39 PM
Todd's90's Avatar
0711, USMC
you would get more hp if you took off the headers and installed just one header. I also would not mess with it unless you had cams.
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 10, 2007 | 07:47 AM
sleepinsol's Avatar
starting over
its a single cam...so it needs a cam. but ur rite, with a bigger cam he would get more power, but u can still get a lil bit from stock cams.
Old Apr 10, 2007 | 11:28 AM
Dorado, PR
thanks sleepinsol, i emailed him
Old Apr 10, 2007 | 12:03 PM
sleepinsol's Avatar
starting over
did he get back to u yet?
Old Apr 10, 2007 | 12:06 PM
sleepinsol's Avatar
starting over
o ya....he will chip ur ecu for 50 bux too.....gave my motor a lil more umph as well. just a thought. outa make a mini me if u want some real decent power from ur single cam.
Old Apr 10, 2007 | 12:23 PM
envee's Avatar
Green with Envy
dude its a single cam, and he didn't ask about ignition timeing. and a ls motor is more performance oriented than a sohc. wow.
'06 Mazdaspeed 6
L3-VDT
'02 S2000... Sold
F20c
B18C1
B18C1 Supercharged
'95 LS... Sold
