Another coolent problem..??//?
Old Apr 2, 2007 | 03:46 PM
FC_V8's Avatar
Default Another coolent problem..??//?
Just got my swap done then.. When daily driving, everything seems fine.. Then my car started to over heat.. i was like ok then its my coolent hoses.. i check all of them and nothing.. so i was like WTF.. then what i notice was my carpet from my driver side and passenger side was WET../DAMP.. and i was like WTF... so i guess some how my coolent is leaking from my engine to my carpet?? any one had this problem.. And then my radiator was emty so i refilled it and it seems fine now.. but still dont konw why that happened..?
Old Apr 2, 2007 | 03:53 PM
PbH's Avatar
PbH
The heater core for your ac system has a leak. An its filtering into your interio try to find it and replace hoses if nessesary. I will warn you its porbably gona be a pain in the behind to get to it. But if you are not planing on using you ac system ever again its a great time to take out the condenser and hetaer core and fan assembly from you dash.
Old Apr 2, 2007 | 04:02 PM
FC_V8's Avatar
F@ck.. so i have to take out my dash?? and i dont have AC in the car.
Old Apr 2, 2007 | 04:06 PM
PbH's Avatar
PbH
but you still have the fan assembly the condenser and the heater core inside the dash. You could also find the hoses that go to the heater core from your engine and loop them. But if you don't use any of that stuff, you could always take it out then you would also be removing quite a bit of weight.
But if you wnat the easy way out find witch hose goes to the heater core an put a hose to loop the fluid.
H.R.
Old Apr 3, 2007 | 10:09 AM
FC_V8's Avatar
yea im just going to loop the coolent back the the block.. i dont use heat anyways.. Thanks alot.. REP will be given
Old Apr 12, 2007 | 05:46 PM
emodept's Avatar
Coolant leaks indicates damaged heater core. That's what I've known with Mercedes heater cores. Try to have it repaired but usually, immediately replacement is the only solution.
Old Apr 12, 2007 | 06:04 PM
FC_V8's Avatar
well what i did was the coolent hose that goes to the fire wall and comes back out.. i just looped it back into the block so i cant use Heat anymore.. o well its Florida.. too hot anyways..
