- Compression low in #3 cylinder
- Can someone help me test an OBD2 LS dizzy?
- H2B series conversion kit?
- help d15b7
- Will these wheels fit a 2000 civic
- 2000 ek front question
- HELP-fuel n ecu issue please HELP---...LOOK
- Having issues.. need some help $$$
- LS Turbo Cams????
- Almost 13:1 comp on stock Y8 cam?
- What Aftermarket Bearings Are Good?!
- 2000 Acura Tl Starting Promblem Help!!
- No Spark....ideas?
- need passenger lower control arm for 92 integra got $ in hand lmk 813 850 6041
- Power steering help
- Higher RPM sputter?
- Civic b18 problems
- window tint on an eg or no????
- 2000 Civic Si Need some advice
- What engine oil do you run?
- problem with 95 civic sputtering when driving please help/!!
- rain gaurds on eg civic??? pics???
- Where to buy a d16y8 block?
- Help Vtec Issue Type R
- Breather/Recirculation box block off
- misc parts
- Will a automatic p28 still work on a manual z6 crx?
- Honda newb
- car starts and runs but only for a few seconds
- auto to stick
- Compression test!!!
- Je Or Cp? which is better?
- Civic auto tranny help?
- 99 Honda civic ex ideas?
- Dash harness hook up
- Vehicle Title question....need some help/opinion
- Fuel rail problem
- where to buy 4x100 to 4x108 adapter?
- 97 GSR vs 97 ITR brake booster, need help ASAP!!!
- grease
- Engine Help with my 96 accord
- I need neils #
- Help! Si Gauges
- lsv help
- ADVICE on GOING vip ACURA TL???
- Integra LS Master Cylinder Fittings
- Its never ending
- Need Somebody To Tune My Gsr Turbo Set Up
- EDM crx power windows ?
- Tenzo R
- Eg Brakes
- B series question...
- My injectors?
- how to check piston compression
- Need Help Asap Car Wont Start!!!!
- power steering rack
- Need timing belt on teg LS done
- obd2a-obd2b?
- gsr v-tec not working
- B series in ef spindle question
- Seeking engine swap specialist/shop
- accord stalling out problem
- 1998 Accord Transmission Slipping
- ACURA TL **rims**
- Someone read these plugs
- Door fitment on EG hatchback, please help
- Can I use a MT Ecu in an auto civic?
- da steering problems
- F22 Wont Start
