94 Teggy /AC help!!!
Have a 94 2dr AUTO teggy and i havent had AC since i bought the car two years ago!..First the whole bracket where the AC pulley goes broke up and i finally got a new one a few months back, i also bought the condenser for the front. All the lines I believe are still in there as well as the AC compressor. Can anyone here hook it up and just get me going , cause after two years living in florida with no AC is killer. PM if needed....
engine building &best
on
where you located?
i love AUTOZONE
i love AUTOZONE
when you have it all setup, make sure you have the system evacuated, and vaccumed down. Nothing worse then going to walmart, buying a can of r134a, putting it in, and having your a/c compressor lock up, due to the moisture in the lines that wasn't previously taken out with an a/c machine. Also you didn't list if it had a txv valve, an orific tube, etc. if your a/c system doesn't have, it won't work. good luck
