ls turbo help ASAP
i just put a turbo on my 98 integra it runs good but when boosts gets to about 6 psi it feels like it starts missing and stops pulling
i have b18b1, t3/t4 turbo, intercooler, dsm 450 injectors, golden eagle fuel rail, fpr, external coil, 10.2mm spark plug wires, ngk plugs, hondata s300, walbro 255 fuel pump
it will blow up if not tuned properly
-Induction Performance
ALPHA Tuned.
-ROQUE MACHINE SHOP
For ALL your fabrication needs.
-ROQUE MACHINE SHOP
If your trying to use a basemap to get by with your not going to have a motor in about a month. Don't drive it...get the wideband in and take it for a short easy drive while datalogging A/F ratios. At least you will then know what is happening inside the motor. Until then you are just asking to blow up your setup.
^ correct
You dont have money? and you have hondata s300. Sell your hondata and get a p28 socketed ecu $100 then get a street tune from a reputable tuner. or you could keep the hondata and get a street tune, but you would need extra $$$ for that.
