Hatch light stays on...
on
yo tr. my hatch light in my cluster stays on even when my hatch on my 1994 integra is slammed close.anyone know a reason that the light might be stayin on? i have looked online and all i get is people saying there damn tail lights wont go off....
Anything will help.
Thanx
chris
Anything will help.
Thanx
chris
TR 5th Gen Civic CREW Member # 04
on
i did i even took a screw driver and let it act like the trunk and locked the truck with it and the damn light stays on....I cant think of anything else other then like a sensor but is there even a sensor. my alarm wont stop freaking going off because of it.
With some Hondas, at the latch there is a flat piece of metal
that works as a switch, and when the lid closes, it will interrupt the ground side of the bulb....
OR
when the lid opens, the flat metal allows battery to go to the hot side of the bulb.
Look first for the top paragraph solution....if a screw fell out, it cannot interrupt the ground, so the bulb stays lit.......
You might have to pull loose the plastic near the latch to
find the switch.-Bob
OR
Lopezchris go to page 1284 of the manual i sent you. The sensor is in the latch. Remove the three bolts and check to see if connector is unplugged. Check continuity of sensor in both states open and closed. Hope this helps
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Senor Honda you beat me too it.
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
