skunk2 stage2 cam problems**** NEED HELP!!!!!!!!!!!!!!!!!!!!!!
Old Jul 6, 2009 | 06:43 PM
djgspot's Avatar
Default skunk2 stage2 cam problems**** NEED HELP!!!!!!!!!!!!!!!!!!!!!!
installed skunk2 stage2 cams in my b16 and now i have a problem engaging in vtec. right at 5500 rpm it boggs and falls on its face... any help out there?
FYI
I have skunk2 valve spring and retaners. the head has recently been machined and im also running a skunk2 intake manifold. stock intake and exhaust.
Any suggestions or advise is welcomed
For sale: Garrett GT2554R-471171-3 (GT25R) Dual Ball Bearing Turbo w/Internal WG.
Old Jul 6, 2009 | 06:50 PM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
It needs a tune if it's still on the same tune from before you installed the cams.
-Winston Churchill
Old Jul 6, 2009 | 06:58 PM
djgspot's Avatar
when they tune it.. what do they adjust?
Old Jul 6, 2009 | 07:01 PM
K20A2's Avatar
A/F,timing,etc.
It won't run right without a tune, and I wouldn't suggest doing it yourself unless you know 100% what you're doing.
-Winston Churchill
Old Jul 6, 2009 | 07:14 PM
djgspot's Avatar
i see. I didnt know someone is able to adjust the A/F without regulator or vafc or something like that
Old Jul 6, 2009 | 08:18 PM
Nandosol's Avatar
Garage Slut
vafc is junk.
It really shouldnt be bogging out with that setup on the stock ecu. If you want you can have your ecu socketed and chipped with a basemap(If obd1 92-95) according to your mods from a tuner. Like John Vega(MTber), Alpha, Jap, or Neil. What year is your car? What chassis are we speaking of? Any other mods? The more info you provide, the more it looks like you want a real answer. I suggest you read this Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28
Old Jul 6, 2009 | 09:55 PM
djgspot's Avatar
besides the mods mentioned above i also have a header and cam gears. The car is a 2000 SI.. I've been given theories on the cause:
1) it could be a build up of back pressure due to the stock exhaust (?)
2) ecu error... (but i doubt it because it worked fine before the installation)
3) its normal to run poorly before its tuned after installing big cams.. (?)
Why is the vafc junk?
Old Jul 7, 2009 | 04:12 AM
integra's Avatar
90% grind 10% sleep
VAFC is not junk,i cant stand when people say this..
If you have a VAFC PM me i will show you how to use it. The vtec cross over is going on and off because of the bigger cams. I had this same problem with my crx a long time ago,tuned it on a VAFC and it was gravy.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jul 7, 2009 | 10:28 AM
djgspot's Avatar
ok. i have one but not installed... wanted to find out if i shoud
Old Jul 7, 2009 | 12:23 PM
custom240sx's Avatar
DC Crew Member #1
They aren't as bad as everyone says they are but they also aren't as good as a real tune. You can use it fine to fix your problem and still pull out some extra power.
