i wana build a ls/vtec
complete gsr or b16 head (I mean complete,intake,cams,dizzy etc) $300-$450
dowell pins $10-$25 ebay (golden eagle,kms etc...)
ls head gasket .oem,felpro,cometic $50- $125
set screw to plug the head $2-$5
vtec or 96 up oil pump $90-$125
water pump your choice 22 tooth (b16,b18c)$50-$100
if you go ^^^ route needs gsr timing belt $35-$65
arp rods bolts if you plan to go above 7800 rpm $45-$50
3 an fittings and braided hoses $75-$100
hope this help.......Omar
^ awesome breakDown other then that wireing it up and the ecu.. and if your car is 96+integra you dont need to buy the oil pump or water pump so u can save money there
i love AUTOZONE
i love AUTOZONE
Babill, very nice breakdown!
._________________________
thanks for the info guys!, appreciate it, i wana knw? wat type of tranny should u use? or should i stay with the same one, ls
TIME AND MULAAAAA=) EQUALS PERFECTION!!!
if the tranny thats in your car is in perfect shape USE it,you will not gain anything if you use a gsr/b16 tranny unless you build up the motor..plus no worries of spending more money on a tranny that may be bad...useing a 10lb flywheel will help you alot if you want to help your ls tranny
i love AUTOZONE
i love AUTOZONE
