- What Do You Think?
- d series a/c parts
- Clifford G4 Alarm Helpp!! :/
- question on 2000 civic front end PLZ HELP
- 68mm Throttle body TPS adjustment
- new swap new problems HELP plz
- i need ek head lights
- DA YS1 tranny problem
- What is this
- Drum 2 Disc Conversion,"COULD THIS WORK"?
- help me build my b20
- troubleshooting ?'s for my ef
- LS Cank question
- Need help axle/hub
- conversion question?
- which throttle cable for ef b series swap
- lowering springs? go lower? HELP!
- 91 Accord runs ruff at idle.. But drives fine..?
- no power to my fuel pump
- Anyone have a link for crx interchangable parts?
- 94 Legend running hot WHY?!?!?
- WHERE CAN I FIND THIS??? Syncro for a GSR TRANNY!!!
- 94 LS runs rich, throwing code 14 IACV?
- 94 civic dx b18b swap questions
- blown head gasket?
- Remote Window Opener ?
- honda helppp!!
- wont crossover to vtec
- camberkit for dc2 helppp
- motor swaps for a 2005 civic lx please
- 94 DC-Play in steering rack
- Need Time Sert Installed Asap
- HELP car died and now wont start HELP
- question about lsd h22 del sol
- auto to 5spd conversion in a CL/accord
- Car not starting
- Anyone here do motor swaps?
- need speed sencer
- need someone change the oil in lakeland i paid 10dollars
- help!
- NEEEED HEEEELLLPPPPP! I need Fseries/Hseries info. Acura cl 2.3 vtec SOHC tranny
- Help!
- Need Advice
- Civic wagon and crx AC stuff
- problem starting my b16 crx
- camberkit dc2
- white smoke out my exhuast
- RSX seats in my si
- injector issue
- DC2 Help Rear Motor Mount Bolt
- i need oil change services i paid 10 dollars and i bring the supplied
- confused on dsm injectors
- ef hatch sway bar
- Went to check oil level... THERE WAS NONE!!
- Fuel pressure question!
- electrical problem!!!! PLEASE HELP!!!
- A/C help!!
- Help Me Please Eg Won"t Go Past 30
- GSR Tranny Grinds. Who can Rebuild it?
- Rack and pinion in a DA
- need help/info k24a4
- 1996 Accord- Tach & Speedo drop to zero when turn signals used.
- Spark Plug wires wont come out!!!
- coilovers
- Honda lip-lip
- engine seized
- Wrong distributor??
- PLZ help Main fuel relay changed.still won't start humid mornings
- NHBP K20a2 Ep3!!!
- y8 swap in a ef. help?
