Manual tranmission fluid change help!
2000
Acura Integra
LS
1.8 DOHC
Manual transmission.
I'm confused when it comes to replacement of the crushed washers.
It would appear that the filler plug is a seventeen millimeter.
Therefore it would need a seventeen millimeter crushed washer correct?
However the drain plug dimension eludes me.
What size is the plug and what size washer does it need?
I have called,
Acura dealer.
Napa autoparts.
Advance autoparts.
Autozone.
No one has been able to help me so far.
This is quite discouraging -- I just want to change the transmission fluid oil!
Please help!
Thanks in advance!
Acura Integra
LS
1.8 DOHC
I have called,
Acura dealer.
Napa autoparts.
Advance autoparts.
Autozone.
Please help!
Thanks in advance!
go to acura and say i need a crush washer for the transmission drian/fill on whatever car
but the head of the bolt is a 17, the body is like a 13 or 15
you can go to harbor freight or any parts store or home improvement store and get some crush washers, and whatever fits works
but seriously, more then once i've re-used the old washers without issue, its really not that big of a deal
F*ck Thieves.
