high compression and pump gas?
ls block
gsr head....
................pr3 pistons 12:2:1
p30 ecu......how we lookin ,to high for a daily driven 93 pump gas car?
plz lmk
gsr head....
plz lmk
F*ck Thieves.
F*ck Thieves.
its only 11.5:1 Im doing the same build. Get it tuned on 93 and you should be fine
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
With GSR head it is close to 12:1. That compression ratio works if the tune is good with cams with large enough primaries to bleed off compression to avoid detonation at partial throttle.
Gracie Barra Clearwater
Set your base distributor timing to 12-14 deg btdc (2-4 degrees retarded) and you will be ok to drive it on the p30 ecu. Your fuel map will be lean due to the displacement & compression differences.
I would ultimately suggest getting the ecu chipped & tuned.
You're trying to not tune a high comp motor and not blow it up?
Are you serious?
Are you serious?
Spend the money for the tune. You can't just go and throw parts at a motor and expect it to make power. If you don't want to tune run a stock motor with i/h/e and be done with it.
