Calling all H swapped Civic's and Tegs
What is your Axle setup with given Mount it.
I want to get a count of how many people run what axle combination with what kit. To see what works best over time.
I used to run DSS Level 1 axles which use the Prelude Intermediate Shaft. This worked great with HCP mounts. Never had a problem. Axles have since then been replaced. Now im running a Accord Intermediate Shaft and a driverside 91 DA axle. I need to replace the passanger side axle still with a 91 DA axle and see if i can get away with running just the DA Inner joint in the trans. OR just swap the Prelude inner joint onto the DA axle.
The reason for me doing this is because when i accelerate in 1st n 2nd (all the gears i have other than 5th) i get a pretty bad vibration (shutter) which i can feel in the steering wheel. Goes away as soon as i let off the gas.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
TR H2B crew #2
That could be from having solid motor mounts. My steering wheel shakes pretty bad at idle because of this. I will check next time if I am having the same issue as you are in 1st and 2nd and I just havent noticed it.
nah this isnt motor mount related. This isnt vibration from the mounts this is axle related. its unbearable.
TR H2B crew #2
TR H2B crew #2
95 hatch h22-t first generation hasport mounts and raxle axles. driven about 18,000 miles no problems at all with vibration but the boot are done for and need to be replaced. (they have been in and out too many times)
i once felt bad cause i had no turbo!! then i met a man that had no VTEC.
95jdmh22a
2008 hasport solid mounts
2008 hasport stg 1s
raised the front of the car an inch or so to get rid of that nasty angle and it takes 7k launches on the bottle in first gear dead hooking on dr's.. and it drives smooth around town no vibrations
2008 hasport stg 1s
Phearable.net!!!
Neil Sutton!!!
Hmotors!!!
Hasport!!!
Im back!!!
Phearable.net!!!
Neil Sutton!!!
Hmotors!!!
Hasport!!!
Im back!!!
Hasport EGH2 mount kit w/ Hasports stage 1 axles, however the boots have been replaced a ton.
Drag racing and hard street driving is fine on this setup, however it seems after each hard autocross event there is atleast one ripped boot. But they're an easy fix so fuck it.
TR H2B crew #2
TR H2B crew #2
i have the hasport egh2 mount kit with the prelude inners and the early integra outer.i believe its 91 or 92,i dont remember since i only changed it once and it was like 2 years ago.i dont street race or nothing like that,i just drive it normal.
And your have no issues with axle vibrations or anything correct?
TR H2B crew #2
TR H2B crew #2
