HELP 1992 legend won't start!!!
i'm tryin to get to work and this fucking car won't start. i'm getting fuel and spark and all this car is doing a just cranking but it won't turn over. it has a brand new battery and i'm not getting a check engine light. i don't think i'm throwing any codes otherwise i'll be getting a CEL. can some one please fill me in on soemthing that i'm missing. i'll be checking this post very often via blackberry so please any help is appreciated. this car has been doing this for the past 1 or 2 months. also my fuel pump is priming like it should but i'm just not getting it to start.
Check Grounds All Tho Your Fuel Pump May Come On It Might Not Put Out Anough Fuel Do To Lack Of Ground......g/l
seffner meet getting started so click here to get inhttps://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
keep in mind the 3 musts for combustion. fuel- that is an easy one to check. use a can of carb spray into the intake. if it tries to run or does run look into fuel problems. second Id try a compression check. if it shows good as well as the timing marks are aligned then it can only leave spark. spark can be tricky as it could be weak or sporadic.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
