Head set?
Old Sep 6, 2008 | 08:09 PM
importeclipsegst's Avatar
Default Head set?
ok building a b20vtec with a b16 head, does it matter which head set(felpro gasket) i get for rebuilding my head? i thought it was the head set for whichever head you use but just making sure before i waste my 50 bucks away. if u have the felpro number that would be great too. thanks
Old Sep 6, 2008 | 08:38 PM
mtber's Avatar
You mean headgasket ?
I would run an oem honda b20 headgasket modified as needed if you are running aftermarket dowel pin adapters.
The felpro gasket for a b20 should work fine, however I wouldn't use anything but an oem gasket personally.
Old Sep 6, 2008 | 09:07 PM
rangcrx's Avatar
engine building &best
^ im with him on this one cause for b20"84mm" headgaset it is about the same price for felpro and honda so i just use honda for my b20/vtec builds
i love AUTOZONE
Old Sep 7, 2008 | 05:07 PM
k thanks guys\
