- Injectors size ?
- my 420a is coming after yall 4g63's!!!!!
- Problem shifting...
- Want a new turbo
- GD water pump/air......belt broke
- Quick Radiator ?
- brake question
- Should I fix mine or buy a new one?
- ARP Head Stud Question
- Mitsu 7cm exhaust
- thanks "mistu" heads
- Update!!!!
- nonturbo head on turbo block, will it work
- I think they went a little bit too extreme with this one!
- idle problems
- Rear Lower Tie Bar Install
- Sunroof Stuck In Tilt Position
- 4G63 MBC Install
- $500 3" turboback exhaust for AWD's...
- Such thing as a recir. O2 with a dump you can open and close?
- Questions help me
- Where is the Starter Relay
- Ignition Coil Pack Problem
- idle help
- Idle help
- what a tragedy...
- 2g GS motor swap?
- any body have a place i can rent to work on my car
- 2G Door Handle replacement
- Electrical Problems
- AnthraxNSB (Cory) Old Talon on Ebay
- need your help - info on 2g eclipse
- Need Help
- Mirage Oil weight?
- help me what make s motor brake up at 4000rpms
- About Slowboyracing.com
- I got scammed with a Crappy BOV
- what do you guys think?
- Clutch/Tranny help
- Help me find my dog!!
- 4g63 block hp?
- need help plx m-300 wideband
- what injectors should i use
- mbc vs EVC
- Wiring harness????
- thought i would share evo 2
- Running Rich, Boost Only Hits 8-9 Psi
- I finally got a good running car :)
- The Buck Stops Here
- 2g sunroof help!
- Ideas for building my GSX
- Talon Build - Pics
- Question about A/F ratio
- Need some opinions.
- Well, it finally happened.
- what oil do you use
- car stalls after driving for awhile
- 95 gst hp
- tranny questions
- Slick Tire and Drag Radial Only Private Event At Bradenton Aug.12th (Sign Up Now! )
- exhaust manifold basics.
- AMS breaks 1000awhp!
- guage question
- I thought this was funny
- flange qustion
- Wheres a good place to get an alignment for dropped rides?
- looking for drew from twincam
- I am a ricer.
- Center shaft in a 2G AWD tranny...
- question about seat brackets
