Anyone have a.....
16g just lying around. I'm looking to borrow one for a few days to do some test fitting. It doesn't matter if the thing is broken, i doesn't even need the turbines. Just want to see if i can cram it into a very tight space. If anyone can help out i'd certainly appreciate it.
Why not just use a 14b then. Its the exact same housings if you plan on a small 16g. Otherwise the only difference in housing size is a 7cm instead of 6cm if you want a big 16g. Only real difference btwn a 16g and a 14b is the compressor wheel if I'm not mistaken.
