View Full Version : Honda/Acura Tech
- K24 Civic Sawp in Miami
- 800 HP Turbo Civic
- Million Dollar Civic?
- Honda wins 2016 Indy 500
- Honda aerodynamic kit
- Hondas are not whiners
- 98 Integra wiring
- Rare 1990 Honda Beat discovered
- B16a SiR II engine being swapped in a 96 civic hatchback. includes parts list
- 05 Accord Navigation help.
- The First-Ever Honda in the US Gets a ........
- Charcoal Can Discussion
- DIY Camber kit installation
- Honda wins Daytona 24
- Tampa Racing Official Event Track Attack Open Track Day
- FEB 6 FEB 7 Two days of Tampa Racing Official Event Track Attack
- Hondas at Tokyo Auto Show
- The Hondells sing..... :)
- Electric conversion for a Honda Civic
- JAN 23, 24 Tampa Racing Official Event Track Attack Open Track Day
- fs/ft rsx racing exhaust for 03 525i ( QUALITY)/cold air
- Not really Fast and Furious, but.....
- 7 Second Honda
- DEC 19 Tampa Racing Official Event Track Attack Open Track Day
- Every 2nd Saturday We are having a free Breakfast in Tampa
- DIY: Mishimoto radiator and hoses install
- HID Bulb replacement
- DEC 5 Tampa Racing Official Event Track Attack
- Can't Adjust Idle Speed
- For only $75.............
- Christopher Deshong Racing Honda
- Pilot shaft pictures different on some transmissions
- Detailing Honda arm rests
- The very first Honda brought into the US
- I just need one gsr fat five asap plz
- Kseries parts and rsx parts for sale.
- Free Hot Dogs and Beer in Tampa on First Saturdays Tampa Racing Official Event
- SEP 12 We are having a free Breakfast in Tampa and ALL cars are invited
- OCT 16-18 Tampa Racing Official Event Lake Mirror Classic
- Join us for breakfast
- SEP 5 Tampa Racing Official Event Open Track Day Open to ALL cars
- How to installing an aftermarket start button
- June 6 Tampa Racing Official Event Open Track Day
- Getting a B18B1 short block built
- Engine Block Cracking - Honda Civic 2008
- Need help doors wont lock and unlock after installing alarm
- radio security code for 05 accord LX please help
- Mini with K20 Honda Engine
- Anyone around spring hill want to make a few bucks? (b18b related)
- tech question???
- d16y8 mini me ecu question.
- How To: Install a clutch 2000 Civic si 1.6L
- How To: Install cold air intake 96-97 Civic
- d16z6 PCV System question
- Tampa Racing Free App
- 1996 Acura Integra GS-R used in 2001's The Fast and the Furious
- Installing radiator in Acura RSX
- Need Help. Please read!
- s2000 cluster to ek???
- 01 Civic question
- When I want to get creative
- When the line is long
- Help, Car Wont Start. expertise advise"
- 96 Honda Civic! help!! Car shuts off every time in neutral!
- Reputable K series Tranny Rebuild shops
- 95 Accord EX starting and electrical problems...please help, can't find answers!!
- Throttle Cable question
- Need cams dialed
- Testing for spark the easiest way
- For other Honda Car Meets
- Changing the brake pads on your Acura 3.5 RL...
- Air Compressor and My Clutch.
- B18C turbo build Questions
- Auto paint shop in Orlando?
- Need help 02 accord 2.3
- D16z6 in 98 Ek Need help-
- 03 Ford Focus-97 civic ex 5 speed coupe Should i trade?/
- 91 da teg wont go into gear
- Got ripped off by mobile mechanic
- Battery not charging...
- Two ways to adjust camber on some cars
- Tie Rod replacement
- Free App for Tampa Racing.com
- 98 civic ek parts
- Honda vs Toyota
- Key won't turn ignition
- dumm question
- Street legal 2 Liter Honda and 350 HP
- 95 Civic Clutch Pedal Sticking... HELP!
- cable to hydro conversion in ef HELP!!
- VIN Check Please
- Teggy tranny problems please help
- 1985-1989 Hona Accord Hatchback Questions
- Spring pins, roll pins
- Tire question, stock eg coupe
- Old school Japanese
- i have a clutch problem
- Clutch Issue?
- How to: avoid spending a lot for a front spoiler :)
- How to: Pulling Honda codes without a scannner
- What happens when the battery light comes on and the ignition is off?
- Rotor over hub brake conversion? Spacers needed?
- Dot5, Dot3, Dot4 What are the differences?
- What do you do when your speedometer reads slow?
- normal water temp for del sol?
- Original wheel paint remover
- Which headlight bulbs?
- Drop in bucket seats?
- Where to look for an x-pipe rattle
- Problem with brakes
- How to find axles that interchange
- Where to do heli-coiling?
- How to: filling a transmission
- Headlights affect engine idle
- Fan. blown fuse, relay, color code
- finding a camber kit
- Converting a suspension discussion
- Discuss lights, gauges, temperature
- Bad fuel pump?
- Why does a shifter move around?
- Customizing valve covers
- Installing different seats
- Engine sleeving advice?
- Spring/strut discussion
- Why does alternator fuse blow?
- Finding a vacuum line diagram
- Non-fiberglass Integra side skirts?
- How to: Finding a higher AMP alternator
- Wiring up ghost rings or halos?
- Does lining up the door edge and drilling some holes work?
- Lights and horn don't work?
- adjustable coilovers versus lowering springs
- Bigger rotor size for a swap
- Bigger brakes
- Bouncing Tach Problem
- Tranny Fluid
- Motor mounts
- Electronic Load Detector discussion
- Overheating discussion
- Car overheating discussion
- D15b7 wont shut off.
- 90 integra gsr vafc
- ac belt
- What size Center Caps for Rota Jmags
- fa5 exhaust on a fg2
- Need a RETROFITTER willing to pay!!
- Dr-21 wheels for sale
- EK side moldings- coupe and hatch the same?
- need help with transmission removal
- 1998 Coupe dx help!!!!!!!!!!! lights flickering
- Best after market clutch and flywheel for k20?
- Inconsistent power
- harmonic balancer?
- Whats a good performance chip for an 09 Honda Accord?
- garret turbo, blue top inj, turbo manifold for the low
- z6 arp headstuds, electric boost controller, cp pistons
- Mechanic puts b16 crank in Ls/vtech? Wtf!
- Anybody know of somewhere I can get tires mounted?
- A/C help
- what model honda did these rims come off??
- for sale: honda acura integra civic eg dc skunk2 rear lower control arms
- Wtb rear struts
- Tranny Issue in 96 Civic ex rattling noise
- HUGE DISTRIBUTOR PROBLEM!! Please help if you can
- 95 Honda Civic Dim Headlight: HELP!
- 92 honda won't start All lights flash even with key out
- 94 Acura Integra For sale
- car studders in first gear take off
- 94 DC2 Injectors wont pulse!!!
- f/sk20a2 swap still in the car
- Radiator Swap/Revving Idle
- 01 CR-V Misfire Cyl 1 and Random Misfire need advice what to do next
- looking for help with my turbo civic .
- 93 Civic starts fine, but stalls shortly after.
- how do I know if my tranny is y1 sir
- Can these old chips be used for a chipped ECU?
- Anyone heard anything about this turbo?
- H22 on 50 shot nitous what spark plugs and gap?
- stripped cam cap bolt threads
- Need help finding a tuner
- Integra Lug Stud
- SAFC needed
- What kinda power am i looking at with my setup. any ideas?
- 94 integra body damage opinion needed on repairs
- EMERGENCY! Need to install ignition switch in 98 Prelude w/ Immobilizer
- looking for the person whom traded in 08 white civic si coupe supercharged
- honda acura integra gsr exhaust manifold header cold air intake
- Need help with tranny 90 civic hb
- WHERE do you get your rhd from?
- Weird whining noise in my 90 accord
- Loss of power when vtec engages.
- Need help from a tuner about o2
- b16 timing belt
- NEW DYNO IN TOWN! DYNO DAYS! 1st & 3rd Saturday Every Month! Alchemy Tuning!
- 92 Integra Getting no power
- Need help wiring problem
- Brake Issue
- Need help with my 90 hatchback *Tranny issues*
- 16x8+20 on an 1996 ek
- ok im having a reeree moment, lug stud issue
- Ek Auto to Manual Swap question!
- 1990 Acura Integra burning rubber smell + smoke
- Just purchased an 06 TSX
- 92 eg sedan d15b7 issues
- B18a1 in eg ecu help
- custom wire harness
- 98 civic hx oil leak
- HELP!! EG P06 Auto ecu throwing codes
- 94 integra ls wont start
- hasport motor mount issue???????
- need ecu chipped
- Need Help! P/S LS swap in an EK hatch
- Please help 97 ek coupe codes p0301, p1399
- HELP! PLEASE!! Coolant leak
- F22b1
- code 2
- Need a Motor 98 EX
- H22a tranny question (M2A4)
- NEED HELP! H22a swap in 96 accord wiring issues
- Cold air intake/ exhaust
- To make more power... How??
- Idle problem
- Civic hatch brake problems locks up when pressed
- solid cel wont go away.
- 95 Acura Integra running extremely rough
- 97 honda civic turbo question
- 96 ek manifold and ecu problem.
- Which clutch cable on swap?
- Jdm front conversion issues.Need HELP
- h22a idles but won't take gas. PLEASE GIVE ANY INFO POSSILBE
- jdm d15b rebuild questions
- Exhaust/K&N Cold Air Intake - Gas Question?!?!
- ECU chipped problem! Please help
- CEL Code 21 Help!
- whats the avergage price to get AC charged?
- Help PLZ!!
- Cold clutch problems!!!!!
- K24a1 for sale>> cheap!!
- iacv/eacv helpp
- b18a1 rebuild
- Weird fuel problem? Help/Advice please!
- Compression Numbers ???????
- Turbo help!!!!!
- Need a good tuner
- EG JDM D15B VTEC swap help! Idling problem!
- 1999 Civic EX Oil leak problem, need help with diagnosis
- Single Cam'R Broke/Melted/Stuck Plug Wires..(NEED HELP ASAP)
- Have Issues with the engine codes..
- 98 civic door lock problem
- DA9 axle problem? HELP!!
