Clutch Issue?
I have a 95 civic cx hatch. I was told I needed a clutch kit and brake booster.
Sometimes when i shift in to gear i can feel it drag. If i pump clutch itll shift smoothly.
Also my brake pedal goes to the floor, and i have to pump it to stop. Other times while in gear it works just fine. But when my brakes work and i try to down shift it feels like the gear "pops" out and its hard to place into another gear.
Is it possible for my brakes and clutch to be related?
Normally brake and clutch are not related.
For both brake and clutch, fill up both separate master cylinders with brake fluid.
Pumping might mean fluid's getting really low.
When it gets low, the symptoms you describe show up.
If filling both master cylinders don't solve the problem, let us know.
We then go to the next step.-Bob
The next step would be to bleed out the old grungy fluid and any old air bubbles out of the lines,
and get fresh, clean new fluid coming out of the lines. I would do the brakes first.
boostedb16a3
Jun 14, 2011 10:40 PM
Jaso0on
Jun 30, 2005 06:49 PM
