ok im having a reeree moment, lug stud issue
Old Jun 16, 2013 | 01:40 PM
moshman1205's Avatar
Default ok im having a reeree moment, lug stud issue
went to change the tire on my eg civic and the stud is just spinning with the nut. so i picked up new studs and to my understanding i have to have the bearing pressed out to change the studs? my wheel is still on the car and the suspension apart. wth should i try next? thanks for any input guys. Devin.
Old Jun 17, 2013 | 08:55 AM
Plzz help its my dd...
Old Jun 19, 2013 | 04:24 AM
Importracer13's Avatar
99CivicSi
Good luck same thing happens to me... The splines either stripped out of the hub that holds the stud in or the stud backed out so its not grabbing... I had to basically heat thru it and grind and cut needles to say that wheel was screwed... When u put the new studs in place 4 little tack welds around it so u don't go thru this again
I <3 BOOST
EM1 Crew Member #16
OVERDOSE CUSTOMS FROM BASIC MAINTENCE TO ENGINE SWAPS, CAR AUDIO , PAINT AND BODY
Honda,Toyota, Nissan,Ford,Chevy Dodge, Everything
14525 62nd streeet north Unit 3&4
Clearwater FL 33760
CALL OR TXT 727 465 8295
Iggy Azeala
Old Jun 19, 2013 | 11:54 AM
True. Will the current studs even back out without removing the bearing or whatever? And yea im gonna cut the stud today when im out of work..
gritt
For Sale/WTB Nissan
4
Apr 25, 2009 12:21 AM
cosworth34677
Jul 14, 2008 05:39 AM
shinmei2006
Nissan/Infiniti Tech
9
Dec 27, 2007 07:07 AM
00siboy
Sep 2, 2007 07:43 PM
