98 Integra wiring
Old 05-03-2016, 05:52 AM
Default 98 Integra wiring
Someone asks:
I bought a 98 integra shell, I was told its an RS but it has a sunroof so I think it was just ABS deleted, vin is a DC4. Car was an auto to manual swap and has an Omega Mundial4 security system.
I'm having some trouble with the wiring and I understand you're pretty good with Honda stuff. Car won't crank from the ignition, I can jump the starter with a probe and it'll crank all day but not from the ignition switch. I can't figure out why this stupid thing won't start and I now suspect it's either A: The security system (though even with the Valet bypass enable it won't crank) or B: The clutch switch (there's no clutch switch on the pedal leading me to believe it's been jumped to itself though I don't know which wires to look for off the harness.
Car is obd2a jumped to a obd1 ecu, I used a lot of parts including the ecu from my running yellow 96 DC4 so the parts should all be good but idk about dash relays. Is there a basic list of things I can check w/ diagrams and whatnot?
Thanks in advance,
Logan
Old 05-03-2016, 05:53 AM
Senor Honda's reply:
Re: 98 Integra Wiring
First check under the dash for something that has a plastic female plug in the area of the brake pedal with 2 wires coming out the back of it. That might be the former brake switch. also check to see if the brake lights come on when pedal is pushed....then get back with me with what you found, color of wires, etc.
Thanks in advance,
Logan
Old 05-03-2016, 05:56 AM
Further info:
Brake lights do come on wires are green and white and solid white it looks like
Old 05-03-2016, 05:57 AM
[h=2]Re: 98 Integra Wiring[/h] If it was auto, it enabled the starter thru the brake light switch. If brake lights work, but starter doesn't work with the key, I would suspect the ignition switch.
Keep the key to cut the car on. Install a manual start button from a Nissan to turn the starter.
Old 05-05-2016, 11:14 AM
The person solves the problem:
Hey, resolved the issue with assistance from my brother whos a mechanic, he traced some bad wiring to the park switch thing, I guess when you do an auto to manual swap you have to jump the wires of the sensor that tells the ignition that the car is in park and the wiring the previous owner did didn't hold up over time, connected those wires and it fired right up. Successful b20z2 swap ^^ thanks for the help though.
Old 05-05-2016, 11:21 AM
Glad you got it fixed. Thanks for letting me know...that's how we get smarter.
With some cars, the brake pedal must be pushed in...with some auto trans cars,
there is a switch going to the park position....with some cars..... both are in place.
I prefer the brake pedal to trip the switch...if you are driving and it stalls,
it can be restarted easier, instead of having to pull off the road, then stop
completely and put the car into park for a restart. In traffic, it's not easy
to just pull off the road.
Old 05-05-2016, 11:24 AM
One wiring tip:
Don't EVER use the blue squeeze type connectors with a lid that closes
over the connector.....over time they almost always have intermittent electrical problems.
Might be great and fast for temporary Uhaul trailers, but bad for a car that is
driven often.
J-PEZ
For Sale/WTB Honda & Acura
11
10-04-2009 05:17 PM
Sourskittle
10-01-2008 10:47 AM
BLK94EGCOUPE
09-01-2008 04:52 AM
fearlessaltima
For Sale/WTB Nissan
4
02-04-2007 11:29 AM
Quick Reply: 98 Integra wiring
