Help!!! Clutch bleeding problem on 99 integra gsr
Old Jan 26, 2011 | 12:50 PM
integra's Avatar
90% grind 10% sleep
Your welcome.....Make sure you thank Pops too.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 28, 2011 | 08:05 AM
BIZZY_420's Avatar
i sure did!!! thanx!!
Old Nov 4, 2021 | 09:50 AM
Stephen121174's Avatar
you need to adjust the rod on the clutch master cylinder. it uses a 12 or 14 mm and it makes the pedal travel. There is a certain amount of pedal movement you need to bleed correctly.
How much travel does it need to have?
Also is the spring on the clutch a must have cause my car didn't have one but in a YouTube video he removed one.
Old Nov 4, 2021 | 07:09 PM
As a guess, adjust it for maximum travel.
It needs to be able to push as much fluid out as possible to get all the air bubbles out.
Count how many flats you rotated the nut, so you can set it back once you are done bleeding.
howeeez
Jul 8, 2009 05:40 PM
Red2GDSM
Mar 8, 2008 07:23 AM
willito4u
Jan 29, 2007 05:38 AM
Crazy Eyez
Nissan/Infiniti Tech
6
Aug 27, 2004 09:57 AM
TropikalSX
6
May 11, 2004 01:56 PM
