Clutch problems
Old Aug 25, 2004 | 11:47 AM
Crazy Eyez's Avatar
Has dyslexia and A.D.D
Default Clutch problems
Ok yesterday i was drinving home from a friends house when my car stopped shifting...so I get home and I checked the clutch master and it was bone dry I added clutch fluid in it and started it up and pumped the clutch and it seemed to be fine...this morning when i went to leave for school the clutch wouldnt even engage so me and a buddy bled the system out and it had alot of air in the lines, after we got done bleediing it it was shifting beautifuly then all of a sudden again it starts not shifting again but heres the thing if I pump the clutch a couple of times it will go into gear....the only gears it has a problem going into is first and reverse do you think maybe I have a bad line or maybe I need a new clutch master....please help me guy....thanks for your time
you sound upset.
not enough time starring into the mirror telling yourself how awesome you are today?
Old Aug 25, 2004 | 11:50 AM
AnTman86T's Avatar
S130 love
Sounds like more air is possibly in the lines.. worst comes to worst buy a new master, they really are not expensive and it will eliminate some problems if not fix it.
Old Aug 25, 2004 | 12:08 PM
Epstein's Avatar
Retired
The brake fluid that was in the clutch master doesn't just disappear magically. You probably have a leak somewhere. I'd bet its at the slave cylinder hose. It's only a few bucks at autozone. By the way, clutch master and clutch slave are about $25-35 a piece from autozone as well.
Old Aug 25, 2004 | 12:44 PM
Matt Vassallo's Avatar
lifelong learner
the dampneer could be going retarded on you also..
rest in peace tim.
Old Aug 26, 2004 | 06:12 PM
Kamikaze Takamashi 's Avatar
Tofu takeout
Damn man will you ever get your car runnning fine?
Save 5 dollars when you preorder with promo code: TAKASC300
Old Aug 27, 2004 | 06:43 AM
Crazy Eyez's Avatar
I doubt it....yea yesterday when leaving school or actually trying to leave school i noticed that the clutch was to the floor and i look under the car to see clutch fluid all over the ground well I know its a leak but now i gotta locate the leak...i ran my finger along the hose where the clutch slave it and it was kinda wet but it could have been from where I bled is....any of you have any ideas to where its probly leaking from...thanks
you sound upset.
Old Aug 27, 2004 | 09:57 AM
knives's Avatar
TR Balla Donor Supreme
It could be leaking from the seal around the pushrod that goes into the master cylinder in the inside of the the car, thats what happened to mine.
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
