Help!!! Clutch bleeding problem on 99 integra gsr
Old Jan 24, 2011 | 02:52 PM
BIZZY_420's Avatar
Exclamation Help!!! Clutch bleeding problem on 99 integra gsr
hey tr.. i need help on bleeding my clutch.. first of all, i juz replace my clutch master cylinder and also the slave cylinder.. brand new.. n now i'm trying to bleed it but its not pushing fluid in the clutch line.. i tried pumpin the clutch pedal several time n hold it down.. but there still no fluid going in to the clutch line.. my clutch resorvoir is filled with brake fluid but the fluid is not going down...
Old Jan 24, 2011 | 03:50 PM
LShatch98's Avatar
i love making you mad <3
sounds like something it clogged or there is a cap that wasnt removed form the packaging. but simple ? are you opening the bleeder screw on the slave its a 8mm.
Proven Power for all your go fast needs
Old Jan 24, 2011 | 07:10 PM
BIZZY_420's Avatar
yeah.. i open the bleeder screw when the clutch pedal is down.. n im pretty sure i got all the caps off.. n there was only two caps..
Old Jan 24, 2011 | 08:13 PM
LShatch98's Avatar
okay pinches in the hard line?
Old Jan 25, 2011 | 12:15 PM
integra's Avatar
90% grind 10% sleep
you need to adjust the rod on the clutch master cylinder. it uses a 12 or 14 mm and it makes the pedal travel. There is a certain amount of pedal movement you need to bleed correctly.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jan 25, 2011 | 12:27 PM
VTECracker's Avatar
MDJ_KUF
its going to take hella fluid to bleed all the air out
try to get ahold of a vacuum pump makes life so much easier
Old Jan 26, 2011 | 09:04 AM
BIZZY_420's Avatar
no pinches on the hardline..
Old Jan 26, 2011 | 09:06 AM
BIZZY_420's Avatar
ok.. i gotta vacuum pump.. but still not putting fluid on the line.. everytime i pump it.. nothing is coming out..
Old Jan 26, 2011 | 09:46 AM
integra's Avatar
90% grind 10% sleep
Did you not try this? This is your problem 100%
Old Jan 26, 2011 | 12:24 PM
BIZZY_420's Avatar
yo.. thanx a lot bro!!! problem fix..
