turbo question/opinions
Old Feb 23, 2005 | 07:25 AM
quickcivic's Avatar
addicted to boost
Originally Posted by InsaneCivicSedan
Think about it this way CJ... Your goal is 400whp... With a straight LS, you will make about 350-370tq at 400whp... Now, on an LS VTEC setup, with 400whp, you will most likely only have 250-270tq
How the hell do you figure 370tq at the wheels with an LS?
My hatch was 2.0L and it was 398whp/294tq... it was a 2.0L LS Block with a GSR head.
Aren't you gonna have to change the RS ratio to make 400whp safely in a LS? Doing that will lower the TQ # since the stroke will be shorter. I don't think I've ever seen a 400/370 dyno on a Honda, ever..
If you have the dyno of those type of #'s, post it.
Old Feb 23, 2005 | 08:21 AM
NChatch's Avatar
i stepped on my weiner!
ouch 60-1ek is hatin on the B16s........................easy now i have feelings!
so what if my turbo b16 makes 72ft/lbs of torque!!! hahahahahaha
that show i launch it at any rpm i want with a MBC............hahaaha(again)
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Feb 23, 2005 | 09:08 AM
The Spectacle's Avatar
Spent more money than you
I knew Chris was gonna catch it for that one lol
Racing Integration
LHT Performance
My tuner is named Alpha
Old Feb 23, 2005 | 09:17 AM
Carlos's Avatar
**International Baller**
nice car testacle!
Old Feb 23, 2005 | 09:25 AM
that's spectacle biatch
and my car is broken
Racing Integration
LHT Performance
Old Feb 23, 2005 | 10:34 AM
Punkinterviews's Avatar
Chavez Motorsports
It'll be back and badder than ever!
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Feb 23, 2005 | 10:43 AM
  #17 (permalink)
lead's Avatar
I'm Awesome
....correct me if im wrong but if you use an ls vtec and you sleave and run different pistons and rods and the vtec head what is the difference between that and a gsr block with the same stuff except for the fact that the ls block has to have an external line run which could make you starve your engine if something happened to it....
i say the only bennefit of the ls vtec is the high compression when you go by built standards the ls vtec just becomes nothing special the gsr would = it power wise and have less chance of problems
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Feb 23, 2005 | 02:35 PM
  #18 (permalink)
mtber's Avatar
Ls r/s ratio is the difference
Old Feb 23, 2005 | 02:39 PM
  #19 (permalink)
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
thanks for the replies. as far as the launch is concerned. im running a aem-ems. (launcch control) so i guess that would take care of alot. my only concern is my tranny. i dont do alot of trac racing and the simple answer of put big slicks on just doesnt cut it for me. if i roll around on 15's i know it would make it longer but is it long enough. i got a set of ctr cams and the head will be completely rebuilt with oem type r internals. as far as who ported my head, first was na200whp. he did an awsome job by the way. good quaility work. but i felt i needed more since i was going all motor so i sent my head out to port flow for a bit more extensive port to the intake and exaust side. nothing out of this world but noticable. i plan on using a sc61 turbo. mainly cause thats what all you fockers keep directing me to go with. what trim and all that other bs, i have no idea. all i know is i will be taking my sweet as time to make sure it gets done right the first time. but say it with me 2 litre ls-vtec turbo..... sounds nasty just saying it!
tamparacing.com
Old Feb 23, 2005 | 02:55 PM
  #20 (permalink)
60-1EK's Avatar
Engineer at the source
Good luck with that AEM traction control. It is a pita to setup. Do you already have the AEM? Whos gonna tune it? Ever think about Hondata? As far as the rev limit is concerned.....those cams and that turbo with a built vtec head will probably make power until 9000. So your rev limiter will probably be around 9200 or so. With that and some 225/50/15 drag radials....you will be able to rev out 4th gear to 135mph. That should be enough for the street with that setup. Run the LS 5th gear and we can race to 240mph
JESUS SAVES
9.69@151 Street Car
JKOBD
