brake upgrades?
Old Feb 9, 2005 | 01:46 PM
Anthony's Avatar
TR <3
Default brake upgrades?
I have an s10 and I was wondering what I can do to shorten my stopping distance.And just give me better everyday braking...My last few cars have had disc brakes all the way around and im not use to them just up front...I have done a little research on pads and rotors...will bigger and or drill/slotted make a difference?
-Thanks
Old Feb 10, 2005 | 04:38 PM
Error's Avatar
Cone Killing Maniac
No, they only make a difference on a track when you're braking a lot in rapid succession.
Pick up some Performance Friction brake pads from AutoZone (free replacement for life) and flush/bleed your brake fluid so that it's fresh, and it'll make a big difference.
Error - CustomTacos.com Zaino Guru
Old Feb 11, 2005 | 04:52 AM
MonteCarlo31's Avatar
I'd tend to agree, a good working systems is better then upgrades, most people keep old fluid in there and other nasty stuff. Also, make sure that things like the master cyl is ok and that there is the proper vacuum pressure to the brake booster.
Old Feb 11, 2005 | 10:32 AM
Anthony's Avatar
TR <3
Thanks
Old Feb 11, 2005 | 01:46 PM
Brandon's Avatar
Resident Dingo
put drill plated rotors all the way around
YOU WONT
Old Feb 11, 2005 | 02:18 PM
Error's Avatar
Cone Killing Maniac
Don't forget cross drilled brake lines.
Old Feb 11, 2005 | 03:26 PM
cross drilled brake lines? you trying to kill the guy? You mean Stainless lines (improved pedal feel) or cross drilled rotors?
Old Feb 11, 2005 | 04:44 PM
Brandon's Avatar
Resident Dingo
yeah i was definately joking.
Old Feb 11, 2005 | 05:34 PM
Error's Avatar
Cone Killing Maniac
accord95
Mar 20, 2004 04:58 AM
RedBaron
Jan 1, 2004 07:22 PM
lstepnio
Subaru Tech
10
Jul 22, 2003 03:19 PM
FearThe4Doors
Oct 30, 2002 08:17 AM
Ffej207
Jun 21, 2002 05:51 AM
