Fix My Hog comes to Tampa Racing
Old May 9, 2017 | 11:45 PM
  #21 (permalink)
[TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
Old May 9, 2017 | 11:46 PM
  #22 (permalink)
View it in your browser. [TABLE="width: 600"]
[TR]
[TD] [TABLE]
[TR]
[TD] [TABLE]
[TR]
[TD] [/TD]
[TD="align: right"] [TABLE]
[TR]
[TD][TABLE]
[TR]
[TD]
SAVE IN SHOP
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
[TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
Old May 9, 2017 | 11:48 PM
  #23 (permalink)
[h=1]Arnott Air Suspension Ultimate Ride Series[/h]
[h=2]ENJOY THIS FREE VIDEO![/h] More great content is available when you sign up for a Fix My Hog Video Membership!
  • Learn at your own pace
  • Access to our extensive library
  • Videos at all skill levels
  • Knowledge when you need it
Learn More
We love “new” here at Fix My Hog. Not just shiny and new but better and new! Arnott air suspension asked us to check out their new Ultimate Ride Series suspension kit and we think it’s pretty kick-ass. Here it is all laid out on the table for you to see.
[h=2]About New Suspension:[/h] Arnott released two new lines of adjustable motorcycle air suspension
Smooth Ride Series is an economical line of height adjustable air shocks for touring models as well as many older and less expensive bikes. Provides a sporty, stock like, ride
New Ultimate Ride Series features Fox dampers with optional rebound adjustment knobs and provide a comfortable, luxurious, ride that is superior to stock and other add on shocks
[h=2]Features:[/h] Arnott’s TruAIR Technology combines Fox dampers with multi-ply Goodyear air springs using a patents-pending design
Superior to your stock low pressure air assisted shocks, air cylinder and canister shocks or those low-tech shocks designed for automobiles
Includes a powerful on-board compressor and handlebar mounted inflation switch
Comes with high-quality mounting accessories and everything you need for a fast flawless installation like more than enough tubing and wiring, a distribution valve, relay and fuse, detailed instruction manual, color coordinated bolt covers and even split loom to protect the air lines.
Kits are custom designed for each motorcycle make and model. For example they are engineered with the same shock travel as the stock shocks and come with an application specific compressor mounting bracket
[h=2]Benefits:[/h] Backed by a Limited Lifetime Warranty in North America and Europe which covers the entire system for as long as you own your bike
Up to 3” of shock travel adjustability so you can quickly lower your bike for stopping, parking or for that slammed look.
But if you forget to air up the shocks – you can still ride it. Since they use the same shock travel as the OE the shocks are designed to not let the fender touch the tire
Arnott air suspension shocks also almost eliminate painful bottoming as long as you have air in the shock’s air bladders
But the most important benefit is the improved ride comfort and safety. Arnott air shocks keep your rear wheel on the pavement and smooth out bumps like railroad tracks and washboard roads – regardless of how much weight is on the bike
[h=2]About Arnott:[/h] Factory is located in Merritt Island, Florida about 1 hour south of Daytona in a 300,000 square foot manufacturing facility which includes a 67,000 sq foot R&D center
Arnott air suspension is one of the world’s leading suppliers of aftermarket air suspension replacement products for luxury cars, Trucks and SUVs since 1989
Developed a line of Adjustable Motorcycle Air Suspension Products about 15 years ago
ISO 9001:2008 certified based on quality management principles which include strong customer focus and continual improvement of robust, efficient processes.
More info at www.ArnottCycles.com or calling 877-900-0247
[h=3]Related Videos:[/h] Arnott Suspension review
Arnott Aldan 11-Way Adjustable Air Suspension System Install
Old May 9, 2017 | 11:49 PM
  #24 (permalink)
Installing Street Glide Forks
Subscription Options
Select your membership plan and get our best Harley how-to videos with 24/7 access to tips and techniques from our professional crew, automatic renewal and our ‘cancel anytime’ policy.
Looking Good
We are close to completing our upgrade on our Street Glide forks. Both left and right side fork assemblies have been reassembled per factory and manufacturers specifications. Our completed assemblies have Performance Machine chrome lower sliders and Progressive Suspension’s FST (frequency sensing technology) monotube cartridge lowering kit.
Triple Threat
The Street Glide forks and the motorcycle are going to look amazing and it is going to handle better than any and all stock Harley Touring models. We have used a combination of parts from three excellent American companies. All parts were engineered to fit and function together seamlessly.
Before installing the Street Glide forks into the upper and lower trees, the new Performance Machine bells need to be installed. The factory hardware is prepped with a little blue Loctite and reused to secure these new, chrome bells to the bottom of the lower tree.
It is a good idea to have a second set of hands available when installing the fork assemblies onto the motorcycle. Slide the fork tubes through the trees until they are in their correct position within the trees. Both sides need to protrude the same, equal distance through the top tree. To do this, you can either use a visual method or measurement method:
Visual method: set the fork height so that the top rear surface of the upper fork bracket is midway of the tapered area at top of fork.
Measurement method: Set top of fork to a measurement of 8.695 +/- .060 in from the top, rear of the lower fork bracket.
Evenly tighten the two lower, and one upper pinch bolts. Finally, tighten the hardware to 14 to 18 foot pounds. Next, we will be reinstalling the front fender, front wheel, front calipers and lower bezel. Looking forward to seeing this m/c on two wheels and leaning on its kickstand.
Old May 9, 2017 | 11:52 PM
  #25 (permalink)
Hollister Rally California video
https://www.fixmyhog.com/video/holli...estyle-001248/
Old May 10, 2017 | 12:03 AM
  #26 (permalink)
[h=1]Steering Neck Adjustment[/h] My Question to y’all, do you think it is reasonable to be charged for a Steering Neck Adjustment at 5,000 miles, (instead of warranty claim)? All the HD Touring service manuals state to lubricate at 1k, 10k and 20k and an adjustment isn’t even needed till 25,000 miles. I took it in due to some knocking in the steering neck area to Mancuso Harley, Houston and they just called to tell me the “steering neck adjustment” would be $125 and that he checked with Harley and they wouldn’t cover it because it’s a wear item. A steering neck adjustment is a wear item at 5,000 miles? Thanks for any advice and comments….BUT I’m on my way to pick it up NOW.
Don S.
Hi Don. I myself would contact someone at h/d about this dealers practice. No I do not think this is reasonable, but if 125 dollars corrects the problem it may be worth it. Years ago h/d had a rash of steering bearings that would settle in the frame and races and cause clunking or banging. I was in the dealer at the time and we warranted many of these motorcycles. It was time consuming but all were covered under warranty. -Wrench Safe, FMH
UPDATE FROM ONE OF OUR USERS:
Dennis, saw the bit from Don S. about the knocking noise and the dealer’s Steering Neck Adjustment. I too had a case where I got a knock once in awhile (got a ’99 Road King). What I found was that the main nut at the top of the forks was about 1/8 turn loose. Found too that the lock plate with the tabs that need to be bent up against the nut weren’t, they were flat against the base. I guess that allowed the nut to get loose. I tightened up the nut, folded the tabs against the nut, and the knock went away. Just passing along FYI in case it’s helpful.
Enjoy all your stuff.
Many thanks, Paul
Have a question you want answered by a Fix My Hog expert? Send us your question here.
Old May 10, 2017 | 12:04 AM
  #27 (permalink)
[h=1]Brembo Upgrade[/h] Hi there, Is it possible to install Brembo brakes on the front of my 1997 Road King?
Via Email
It is not impossible, but they definitely will not just bolt on.
Related Fix My Hog Videos:
https://www.fixmyhog.com/video/front...ervice-009556/
Have more questions? Check out our Q&A index page to find some answers.
Old May 10, 2017 | 12:05 AM
  #28 (permalink)
[h=1]Saddlemen Desperado and Drifter bags[/h]
The Desperado and The Drifter
This isn’t the name of a Cowboy movie or even a country duo. These are the names of some of the most popular saddlebags for Harleys. The Saddlemen Desperado and Drifter lines of bags can be seen on Harleys across the country and it’s because they look great, are durable and can pack what you need with ease.
Saddlebags are the easiest way to carry what you need on your bike and the Saddlemen offerings are as good as gets in that category. When you choose either the Desperado or Drifter, you are getting the bags that set the standard in motorcycle luggage. To add a little flash, choose the Desperado line. The Desperado bags feature chrome studs and conchos to add some shine. The Drifter bags are sans conchos and chrome studs to provide a more clean and sleek look. Depending on the rest of the style that you’re going for, either the Desperado or the Drifter will complement any bike.
The bags are covered in Saddlemen’s own leather grain, water-resistant SaddleHyde™ that looks and feels like real leather, but is far more durable. With it, you still get the supple feel and look of a high quality leather, but it is very weather-resistant and does not require a whole lot of upkeep.
Upkeep on with the Saddlemen Drifter and Desperado saddlebags is fairly simple, in fact. A damp cloth will do the trick almost all of the time. You also don’t have to worry about the SaddleHyde fading in the sun after prolonged exposure. The rigid construction of the bag will allow it to hold its shape, whether the bag is packed to the rim or while it is completely empty. You don’t have to worry about the bags being saggy when empty or bulging when packed. In other words, they are going to look great no matter what.
Because the saddlebags are a bike specific fitment, you can be sure that they will not only look like they belong on the bike, but that installation is as straightforward as it gets. When you get the standard bags, the only modification that you may need to make is relocating the turn signals. The saddlebags with built in LED marker lamps will require a bit more work, but can still be done by just about anyone. You simply install the mounting hardware to the fender struts and you are good to go. The bags come with everything that you need to fit them onto your specific Harley.
The ease of use is another huge feature that riders love. Saddlemen uses QTL (Quarter Turn Locking) pins to attach the bags to the mounting hardware. This lets you quickly and easily remove the bags from the bike. Plus there are handles on each bag to carry them wherever you need to.
Practicality and style are joined together at the buckles as well. Hidden under the great looking straps are lockable buckles that make opening and closing the bags easy. And because the bags can only be removed from the inside, theft is greatly deterred when the buckles are locked.
If you love the look of the saddlebags and want the rest of your bike to continue that look, Saddlemen has a variety of amazing seats that match both the Desperado and Drifter bags. Saddlemen seats are made for both style and comfort and they have a variety of seat profiles to choose from. You will not only get the look that you desire, but you will also get a far more comfortable saddle.
You don’t need to be an outlaw or loner to be able to enjoy the Desperado and Drifter saddlebags from Saddlemen, though you may feel more badass once they are on your bike.
Head over to Dennis Kirk to find the Saddlemen saddlebags for your Harley and then check out the Fix My Hog installation video and you will be ready to ride in no time.
Old May 10, 2017 | 12:06 AM
  #29 (permalink)
[TABLE]
[TR]
[TD][/TD]
[TR]
[TD][TABLE]
[TR]
[TD]
SUNDAY DEAL
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
[TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
Old May 10, 2017 | 12:07 AM
  #30 (permalink)
[TABLE]
[TR]
[TD][/TD]
[TR]
[TD][TABLE]
[TR]
[TD]
SATURDAY SPECIAL
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]
[TABLE]
[TR]
[TD][TABLE]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[TABLE="width: 100%"]
[TR]
[TD="align: center"]
[/TD]
[/TR]
[/TABLE]
